car won't start after battery disconnect
car wont start now after i disconnected and the reconnect the battery? checked all fuses too?
i was installing doors sills and blew a fuse and replace it (blew a few fuses already and replaced them and everything was fine) but i don't know why its won't start, car will turn on but won't start
im not sure, but when i hook up the battery i can use the smart entry system and i can turn on accessories. but my display doesn't say "depress brake and push start button to start engine" or something like that.
im gonna try and check the "starting system" fuses.
has anyone ever had this problem it was starting fine but i had all these warning lights come on but was still drivable just hard to steer. and back up camera wouldn't work so i guess the ecu wasn't set. so i unhooked the batt and reconnected after a few mins and no more warning lights except the lights that go on when the ignition is in on mode. but no start now lol can't even drive it to the dealership. b4 that the gas light was on too so i filled in more gas to eliminate that possiblity.
i know this is a simple problem and i don't want lexus to charge me an arm and a leg to get it diagnosed.
help plz ne one
help plz ne one
i was using a voltmeter and i had the car on. i grounded the the voltmeter and touch the positive side of the sills just to see if i would get a reading, then guess i accidentlly moved the neg probe and re-gounded it without moving the pos probe off the postive wire, so when i touched the neg probe to the body again i hear a spark and i i checked the same fuse that i kept on blowing and it was blown. so i replaced it no big deal. car started up fine still after that. but the vgrs took so long to kick in and no rear camera when i shifted to reverse. so i got home turned off the engine give it 5 mins and when for a 10 mins drive to get something then cam back offed the car and wait about 5 mins then i unhook the battery to try and reset the ecu. and it did when i hooked the battery back up i guess the ecu was loading on the nav screen and i thought all would be fine. but then i tried to start it up and wouldn't.
i don't even get the "key is not detected" or "depress brake and blah blah blah" messages. that is what exactly happened
its alive!! dont' know what i did but i just ended up checking almost all the fuses and then i tried to start up the car and it work weird. maybe something was loose hehe
thanks for all your in put.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
clynnh1230
07-18-13 05:28 AM
