Rear heated seats
Old 08-26-09, 11:51 PM
THE.K.W.C
THE.K.W.C's Avatar
So i went to ACDC tonight and it rained all night, me and the 3 girls i went with were soaked thank god for the rear heated seats. There was only 2 min of *****ing that there asses were cold after that the ride home was very enjoyable
Originally Posted by IXI187IXI
awesome job! just curious, did you check into getting cool/heated pads?
ya i check no one makes after market cooled seats. I thought about using CPU water cooled lines and a running them trough the seats but you would feel the lines and im not sure how cold it would feel through the foam.
"Do you usually leave your seatbelts buckled in without passengers?!"
lol ya after i clean my car i do that my seat belt buckles rub my seats and make marks and there a ***** to get off
Old 08-27-09, 12:01 AM
arnieosp
arnieosp's Avatar
Do you have a link to the retailers, or whoever you bought the pads from?
Old 08-27-09, 12:16 AM
THE.K.W.C
THE.K.W.C's Avatar
this site has the same address as on the box i had. I bought mine off another installer.
www.heatedseatkits.com
The ones i used were the carbonfiber set
Old 08-27-09, 12:31 AM
arnieosp
arnieosp's Avatar
Thanks, I will check into it.
Old 08-27-09, 04:23 AM
IXI187IXI
IXI187IXI's Avatar
that sucks no one makes a cool/heated pad and im sure to probably buy the parts at the dealer would be an arm and a leg
Old 08-27-09, 06:59 AM
Yang1815
Yang1815's Avatar
That's when you suggest taking off the wet clothes and all cuddle together!
Old 08-27-09, 07:55 AM
IXI187IXI
IXI187IXI's Avatar
and play whos in my mouth
Old 08-27-09, 09:30 AM
Yang1815
Yang1815's Avatar
That... would... be... correct!!!
Old 08-28-09, 08:53 AM
THE.K.W.C
THE.K.W.C's Avatar
god damn the girls love them they get super hot super fast...I even have to turn them down to low
Old 08-28-09, 10:52 AM
Yang1815
Yang1815's Avatar
Keep it on high and play "it's getting hot in her~"
Old 08-28-09, 01:41 PM
BKE420
BKE420's Avatar
nice mod...i bet that ac/dc concert was awesome. get the seats super hot then play dirty deeds....i miss bon...saw their concert on that palladia channel.
Old 09-02-09, 07:08 AM
greg0723
greg0723's Avatar
how do you take the rear seats off is it hard? also the center console. im seriously thining of doing this.
Old 09-02-09, 04:14 PM
THE.K.W.C
THE.K.W.C's Avatar
center console was easy as pie once i found out the rear vent section pops off lol.
The rear seats come out of the car super easy just pop out the bottom by pulling up on the front of them. then the back part needs to be un-bolted 4 times on the bottom, then you lift the rear head rest and pop off the the circle covers and undo 2 more. Then it slides right out. DONT bother undoing the metal rings just cut them and pull back the leather cover slowly undoing/ cutting the rings as you go ( you only need to open up the seat enough to get the pad and your hand in). Slide the pad in, tape it down then used zip ties to tie the leather to the seat.
Old 09-02-09, 04:15 PM
THE.K.W.C
THE.K.W.C's Avatar
Ill take pictures of removing the center console/ rear seats tonight and post them up.
Old 09-03-09, 09:22 AM
slk_dds
slk_dds's Avatar
If I remembered correctly, they put four of those "PC fan" inside of each front seats. So I guess if you really want to add the cooling to the rear-seats, you would have to cut some of the foams to fit those fans.
Man you are so right about the freaking marks made by the seatbelt buckles, they do leave nasty marks on the leather seat!!!
From now on I will either buckle them up or put condom over them (jewely bag or ceramic wrap)!!!
Thanks for pointing it out!!!
Quick Reply: Rear heated seats
