Dirty Wheels from Brakes!
My front Wheels of my GS460 are becoming black from the carbon from the Brakes.... really eliminating the glitter of the magnificent design :P; any ideas of how to clean them? Will water and a clean towel do the job? or is there a specific chemical?
soap, water, a sponge and some elbow grease. It comes off easily unless you let it sit there for months. There are spray on cleaners to help dissolve/loosen the dust. Any autoparts store has them. Talk to your dealership about having the low dust brake pads installed. There was/is a TSB on that.
steviej
steviej
I never go longer than a week without atleast spraying my wheels with a hose. the longer you wait the harder it is. i only use water because of all the horror stories you hear about wheel cleaners.
if you want to lessen your brake dust, try switching to a ceramic pad which gives off less brake dust.
Best to use Meguiars wheel cleaner or even just regular car wash mix.
I would recommend that you regularly wax your wheels. And if your wheels don't feel smooth after washing, clay then wax the wheels. The wheels are a painted surface just like the rest of the car. Regular waxing helps protect the wheel, maintains a smooth an slippery surface, and attracts less dust.
I wax my wheels every 2 weeks.
Try Invisible Glass Cleaner. I've been using it for years and it makes those rims Shine like crazy. Just spray them down liberally and clean off with a cotton rag. It's strips the brake dust off like nothing. The reason it is my favorite is it is a one step process. Even if the dust is caked on, just gun them down heavy with the Invisible Glass and it leaves it streak and spot free. ESPECIALLY CHROME!!
There is a TSIB to replace pads with dustless ones. I just did it a week ago on my "new to me" 2007 GS450h. Took all of an hour. It helps if you bring the text of the TSIB with you since some service advisors are clueless.
