Grom USB....WOW...it works!
#61
that sounds great. :w00t:
Is this the one U got? http://www.gromaudio.com/store/usb_a...-usb2-toy.html
I wish it can play avi or divx too. It would be much much sweeter.
I don't really care to play video in the car, so a usb stick containing a zillion MP3s is perfect for me. One of these days I'm going to try hooking up a usb external HDD just for giggles.
#62
My old Camry had 6 disk changer and can play mp3s, I still get bored after awhile.
I bought a $30 player to plug into the TV at home and it can play mp3/jpeg/avi too. So I expected this $130 thing can do all that too.
#63
Nevermind what I said before about it being all fixed now. After a while, it's no longer reliable again... starts up sometimes, other times not. I am thinking of going back to the previous firmware now, as at least that seemed to start every time with the right usb stick... now even with the stick that would work every time on previous firmware is giving me trouble.
I don't know what they're smoking over at grom, they just can't seem to get it right. Back to only being moderately happy and that's only because the cost was low.
#65
#69
ISSUES I seem to have is the USB stick is not recognized when you turn on the car. I found myself unplugging the GROM unit from time to time to reboot it and that means taking off the center console shifter cover. What a bummer. I've even updated the firmware 9.2.09.
Hey BOBTECH...how did you get around this problem?
Think I'll fix this problem by hooking up a switch to the power wire. When working, this thing is great. Bobtech was right. It will recognize more than 6 disks. I've created 17 disks on the stick. So this unit should recognize 99 disks with 99 songs each. Pretty cool. Will let you know what happens with the reset/power switch.
https://www.clublexus.com/forums/gs-...tly-to-ml.html
Cheers!
#70
Dice and other mentioned on this thread has some more stable products:
https://www.clublexus.com/forums/gs-t...tly-to-ml.html
Cheers!
#71
While I still have intermittant startup problems with GROM, it is much less frequent now and last I heard from them they said they were rewriting the startup code from scratch to try to address the issues people have been having.
They are very slow in getting updates out, though, so I'm not sure when I'll see it and if it will even fix it 100%. Overall I am fairly satisfied with it's performance for the price. Other than occasionally not startup up right, it does a good job.
#72
Sorry to revive an old thread like this but I just wanted to post that GROM has finally put up (unofficially) a beta version of the firmware (version 38) that promises to hopefully correct the intermittant startup problems that have plagued the product since I bought it.
I haven't had much of a chance to really test it out properly (need to try many more startups, with a bunch of different usb drives before I can declare victory) but so far so good.
#74
Okay well, the problem surfaced again... started car, nothing. Audio is "off" and the GROM unit (CD2) was not showing up in the system at all. Had to turn "on" the stereo (press volume) and listen to the radio or a cd until I turned off and started the car again.
GROM is now wanting to RMA the box so they can examine my unit and send me a replacement. I can only hope that they've done something to improve the hardware that will make a difference here. I think I've had my center console taken apart a good half dozen times already by now... I think I can do it in the dark.
#75
BinaryJay, thanks for keeping us updated.
I think a good solution is get a small mp3 player and a noise isolating headphone. Those isolating headphone are producing some amazing sound, and it also isolate road noise. Only down side I see is it does such a good job of isolating noise that ambulance noise won't get to U and U might get a ticket for it. LOL
