Fuel Cleaner Okay???
Old 09-03-09, 04:02 PM
Ice350
Ice350's Avatar
Default Fuel Cleaner Okay???
I think I read somewhere you're not supposed to use the fuel/injector cleaners/additives on the market....that they somehow cause damage to fuel injectors. Anyone else heard that?
Old 09-03-09, 05:17 PM
HotShotEng
HotShotEng's Avatar
First of all, I'm not sure why you want to use the cleaner in the first place. Today's gasoline all ready has additives to prevent deposits from forming on the injectors. Having said that, yes you should be concerned. The same chemicals used to remove deposits not only clean the injector they also eat away at the injector itself. The most common limit with these cleaning systems is three times then the injectors will need to be replaced. I suggest unless you are experiencing problems such as rough idle, hesitation or no power, don't add any of the additives currently on the market.
Old 09-03-09, 05:32 PM
Ice350
Ice350's Avatar
Well, there is a reason. The 06 GS sometimes hesitates when accelerating. Had the tranny checked several months ago so dealer says it's okay. Next thing is dirty gas. Wifey buys gas from all kind of places. RaceTrack, 7Eleven...whereever it's cheaper. I tell her over an over to only use one of the name brand super but she'll stick cheap stuff and sometimes uses midgrade.
If using the cleaner is an issue, she's just gonna have to deal with it.
Old 09-03-09, 07:20 PM
HotShotEng
HotShotEng's Avatar
I've heard this issue, accelerator lag, before on other GS threads. Unless it's really severe, sounds like the same problem others are having. Buying gas from dubious sources is not a good idea though especially if the station is old or rundown looking. Water that can accumulate in the underground tanks at these old or rundown stations are murder on injectors.
Old 09-04-09, 08:21 PM
steviej
steviej's Avatar
excessive use of fuel injector cleaners (like every other fill up) can cause damage.
I have used a bottle at every other oil change on my last four vehicles and so far no problems.
steviej
Old 09-06-09, 12:13 AM
I8ABMR
I8ABMR's Avatar
I am pretty sure its safe. Even with direct injection it should be ok. If you are worried about it you can consult your manual or even call Lexus corporate
Old 09-06-09, 03:03 AM
Ice350
Ice350's Avatar
Well, I'm not really worried. I think wifey drives too fast anyway. The hesitation slows her down.
Besides, if a member is using it every other fill-up, I should be able to use it once or twice a year....as I have always done.
renatodato
07-29-10 04:09 AM
WhatYaGot
10-28-09 05:46 PM
HoTLeXuS
02-20-09 10:36 AM
kreativ
Maintenance
21
07-28-02 02:06 AM
zushwa
Maintenance
23
01-28-02 03:32 AM
Quick Reply: Fuel Cleaner Okay???
