drop down panel switch
the top right corner of the drop down panel (side view mirrors, etc.) has an unused button. It feels like all the others, but I haven't pulled it apart to see if it has contacts or a way to tie into it from the rear.
Has anyone looked at using this factory button for anything?
executive matchup
i've asked this question before. it appears to be a function only available for jdm GS only. my original guess was it may be for the jdm hid fog lights/led daytime running lights.
Not a GS owner (yet), however could it possibly be a switch for Asian/ Euro market cars that feature Power Folding Mirrors? As it would probably be necessary considering the narrower roads and parking space.
Yeah I've noticed the switch but wasn't sure what it was for. I've been under the impression that US spec GS don't have auto folding as per owners on this forum and Lexus' website. I apparently misread that info.
Thanx for clarifying that for me.......Just one more reason to buy a GS!
Ok here you guys go:
The flip down box takes about 10 min to get out with the help or a phillips screw driver.
IMPORTANT!!!!!
If you try and take the box apart there is a ribbon cable inside of it so be careful when you open it up. You must disconnect it before you take it apart.
![](http://i82.photobucket.com/albums/j252/thekwc/IMG_3584.jpg)
![](http://i82.photobucket.com/albums/j252/thekwc/IMG_3585.jpg)
![](http://i82.photobucket.com/albums/j252/thekwc/IMG_3586.jpg)
Top left of the black rubber is the spare button
Top right of the green is the spare button circuit.
I took this apart to find out if i could use the switch for something. Like i first thought you CANT you will not be able to cut the computer board, and there are resistors on the back of the buttons spot. The only thing you could do is cut the circuit out and then attach wires onto that circuit to make the button work but I'm not sure what this circuit is used for I would need to see the cars wiring diagram to find out. hope this helps
IMPORTANT!!!!!
IMPORTANT!!!!!
IMPORTANT!!!!!
GREAT job in digging into this. I appreciate the effort!
IMPORTANT!!!!!
IMPORTANT!!!!!
What is everyone trying to place there anyway
