Front fender mods...
Who has done them on the 3gs
Dropped the car on coils this past week and it looks perfect. Between my "fat" tires and offset I rub up front basically where the fender on the back start to get thicker. There is a screw right there also where the fender trim piece was bolted. Looks like the the front portion is already factory rolled/shaped. Had to raise the car back up in the front last night so I can drive the car.
I know a few are on bags and lower them me (bags/coils) so what did you do
Please post any pics you have also![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thank you!
here is what it looked like yesterday am...
![](http://gi265.photobucket.com/groups/ii236/2ZC4482GHO/Ksport2.jpg)
Thank you!
![](http://gi265.photobucket.com/groups/ii236/2ZC4482GHO/Ksport1.jpg)
I use to rub alot, where it started to eat out the rear inner fender lining. My rims are 40 offset and the tires were 245/35/20 in front. I got tired of the noise so I switched to 30 series and there was no more rubbing.
If you are already on 30 series tires, you may have to just remove the inner lining. Your drop is def lower than mines so you may have no choice but to remove the inner liner.
I can go lower but I would have problems going up my driveway.
Here is a pix to ref
![](https://farm3.static.flickr.com/2586/3770564108_344b49c57e.jpg)
moreover, the stretching from 265 will also help on clearance, otherwise i might rub more
i did the same, but where the lip goes from 2 layers of steel to 1 layer (right at the apex of the curve) i have a little crease. maybe he didn't heat it enough. sucks, but the shop that did it didn't charge me so i really can't complain too much. lol. i rub a little bit both front and rear, but that can be fixed with a little grinding. on a different note - passnu - that isn't the stock rear spoiler is it?
front - 245/35/20 on 8.5
rear - 275/30/20 on 10.5
Thanks for all the replies
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
I am more worried about the fender and the tire catching. Where I was at, with my offset/tire, I could barely drive home. I had a hard time going up my driveway...
haha mike at least now you see all the rubbing problems. you have even more aggressive front offset and tire size than me, so more work for sure
i have shorter tires so i don't rub that tab as bad, but it was rubbing until i did the fixes, and now it's good unless i hit a very very bad dip.
you are absolutely correct you do NOT want the tire to catch on the fender. happened on my gs400 and all you'd "enjoy" is a loud boom sound and the fender blown out. it's not good. definitely raise it back up and have the fenders rolled as much as needed before dropping it down again!
I have to admit I think I heard a slight rub while I drove fast through a parking lot entrance that had a steep rain gutter at the entry area. In the end I guess the 245/30 is the best bet unless you want to jack the car up a little. I am debating on taking the car up 1/2" or switching back to the 245/30 . I have to admit I drive a lot and after 7 years of lowered cars I am getting a little sick of chasing perfection all of the time. I feel like I am forever getting new tires and/or trying to get them balanced just perfect or having them flipped and still having to repeatedly return to have the balance redone. I am seriously thinking of raising the car up a bit and getting a set of Michellin Pilot sport A/S plus with a freakn 500 tread wear rating. Imagine..... the luxury of tires that last more than 15K. I cant wait. In the end when we slam our cars and it looks cool for the people outside the car. The dude inside the car has to suffer with tire wear and poor ride quality though.
Its a tight rope. looks vs practicality
Just found this. I guess I am gonna give the 255/30 a chance
The load carrying capacity of the replacement tires must always equal or exceed the load carrying capacity of the original equipment tires.
The replacement tire must have a maximum load carrying capacity equal to or greater than the maximum load carrying capacity of the original equipment tire. Refer to the tire placard on the vehicle for the recommended inflation pressures of the original equipment size tires. These pressures must be maintained as a minimum. Do not exceed the maximum pressure indicated on the tire sidewall. Tires which are loaded beyond their maximum allowable loads will build up excessive heat that may result in sudden tire destruction.
Do not exceed the gross axle weight ratings for any axle on your vehicle. Consult the vehicle placard and/or owner's manual to determine the gross axle weight rating. Following the loading instructions of the vehicle manufacturer should insure that the tires are not overloaded
they also discussed how when you make hard turns in your car it adds more load to the tire. Over loading the tire will also heat it up over it normal temperature range. Add this to the 160-180 deg road surface temps temps in the desert with high speeds and you have a recipe for a failed tire( bubbles in the sidewall or split tread) . I am going to raise the front and the rear up 6-8 mm to allow more clearance and see if I cant manage 20k out of a 500 tread wear rated tire. my concern now is the Michellins are a little fatter than the Falkens
