How to program one touch moonroof operation?
Old 10-16-09, 10:02 PM
TwentyTen
TwentyTen's Avatar
I tried every combination I read and now the situation is worse: When I press either button, Open, Close, Up, Down - they all do the same thing. There is no STOP function. They just go on to the next instruction. Pressing DOWN will open the sunroof.
Please help. This is FRUSTRATING.
Darius
Old 11-04-09, 12:51 PM
mesa42long
mesa42long's Avatar
Default Fixed it!
I too was having the same issue after the battery died on my '06 300. I held the up button down until it tilted up, back down, slid opened and then closed. After doing this it works perfectly.
Old 11-04-09, 03:55 PM
TwentyTen
TwentyTen's Avatar
YES!! That was it! Just tried it an my One-Touch is working again! Thanks man!
Darius
Old 03-31-10, 11:04 PM
LexyLisa
LexyLisa's Avatar
THANK YOU! Worked on mine!!! SWEET!
Old 04-01-10, 12:15 PM
energie8
energie8's Avatar
What the hell, I cant seem to get it working.
Hold open for approximately 10 seconds all the way till it stops.
Hold close and close it then hold open again for 10 seconds?
something Im doing wrong?
Old 04-01-10, 12:36 PM
IXI187IXI
IXI187IXI's Avatar
you dont switch buttons, you just keep holding either the open or the up button til it cycles thru.
Old 04-01-10, 01:25 PM
energie8
energie8's Avatar
Ohhhhh, got it to work now lol, thanks!
Old 07-04-10, 05:13 PM
corpnupe85
corpnupe85's Avatar
Hello All,
I just purchased an 06 GS 300 (On July 2, 2010) with the same issue regarding the moonroof. Thanks to your suggestions, I was able to reprogram the 'one touch' operation of the moonroof.
Thanks!
Old 07-04-10, 06:01 PM
ingoodtime
ingoodtime's Avatar
Bought my 06 gs 300. And had the same issue. First the
service greater toldme nothing was wrong. Then iread about
1 touch operation and went back. Think they said it was
bad memory in the sunroof motor. Glad I had the
extended warranty because the repair was about a grand.
Old 11-09-10, 12:07 PM
jea
jea's Avatar
sorry to bring up an old post.
I went to test drive a 06 GS450h. I play with the sunroof and open by one touch but have to hold the button to close it. Is that normal? The dealer told me it is suppose to work like that but it seems kinda weird to me to operate that way.
Old 11-09-10, 01:43 PM
BinaryJay
BinaryJay's Avatar
Mine closes all the way but you have to hold it for a second, just touching it doesn't do the trick.
Old 11-09-10, 04:13 PM
jea
jea's Avatar
hmm.. I should go for another test drive before purchasing the car. What if I have to hold it to close? Can the reset trick solve it?
Old 11-09-10, 04:39 PM
corpnupe85
corpnupe85's Avatar
Have a mechanic at the dealer solve this issue for you!
Old 11-09-10, 07:45 PM
BinaryJay
BinaryJay's Avatar
If you have to hold it to close, you'll grow hair on your palms and you'll go cross eyed. I don't know, try it.
SadleGoose (01-01-21)
Old 02-22-11, 02:19 PM
jackgs
jackgs's Avatar
another great post on this great forum. Thanks guys..
Quick Reply: How to program one touch moonroof operation?
