Fender trimming tools and techniques
I am excited to check it out. You have great taste as I can see from your current set up so I am sure the next set up will be no less classy.
I just filed down another millimeter or so but filed a screw down a bit to far and it popped out with its sleeve. I managed to get it back into place but I am done messing with it. I know I remove the plastic fender lip but I think it looks good and may even make the car look an extra mm lower![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Thanks for the compliment!
Hey man I just speak the truth. I actually ended up taking my car into a shop today and having the fender lips trimmed on both sides. They also popped out the screw I jacked up , tapped a new hole with a small drill and put in the exact same screw ( they had some on the side from all of the fender mods they do most likely). In the end the fenders look trimmed but not man handled. I will keep my ears open and take it back if needed, but I think I should be good to go. I m pretty sure that this 500 tread wear rating is worth all of the drama.
I hit a bump in the highway so hard my head hit the roof of the car and I had a slight hint of rub so I shaved down the rear fender brackets/ support piece to allow more clearance. I am crossing my fingers but I think I nailed this time. Then again thats what I said the last time
Thats why when I took it for fender mods I demanded that we shave and trim rather than roll the fenders. I have done amazing things with elbow grease and a metal file. I have filed down the inside lip of the rear fender by at least 5 mm and the bracket I probably removed/ filed 3mm of the bracket. I didnt hear anything this morning so I am hoping that it did the trick. I will admit though that I have been driving around trying to get the thing to rub as much as possible. So when I even did have the rubbing it was only induced by a bump and a speed that sent my head into the ceiling of the cabin of the car.... not normal driving to say the least
I was a bit concerned when the owner of the shop pulled out a waiver for fender rolling. I am glad I didnt do the roll. shave is more laborious but more controlled and can be done in baby steps
XenonES3
03-11-03 03:08 PM
