20" rims offsets - will it fit?
11-05-09, 10:31 PM
Hello everyone,
I plan to pick up some 20" rims. Will these offset fit my 2008 GS350 with no rubbing or mods needed?
front wheels are 20x9.5 and back wheels are 20x10.5 with offsets of +38
Front
245/35-20 offsets +38
Rear
275/30-20 ofsets +38
11-06-09, 12:37 AM
any advice here would be greatly appreciated!
11-06-09, 12:39 AM
Yea, you shouldnt have a problem. The problems begin to show when you start lowering it
11-07-09, 03:20 PM
Yes you can make those work. You will be flush in the rear more then the front but they will work. Are you going to lower the car?
11-07-09, 03:59 PM
Well the front tire is overspec and 20x9.5 is pretty aggressive in the front. Will need fender mods I'm sure.
11-07-09, 04:08 PM
its close if it doesn t work you can do fender and wheel well mods to make it work
11-07-09, 04:39 PM
Thanks for the input fellas! Yes, I plan to lower it.
11-07-09, 09:13 PM
Quote:
Originally Posted by
greenTea
Time to shave then!
11-07-09, 09:32 PM
^ agreed. those offsets are pretty aggressive.. you will need fender mods both front and back if you are lowering your car.
12-07-09, 03:24 PM
How do 20x8.5 +31 and 20x9.5 +37 sound on our cars?
12-07-09, 11:21 PM
TWong1200
Its doable, but its gonna be impractical to drive
12-08-09, 04:30 AM
ideally you want something like 35mm-38mm offset for a 8.5" wide wheel up front and something along the lines of 43mm-45mm offset for a 10" wide wheel in the rear
12-09-09, 06:38 AM
nah i dont think u will need any fender mod at the front , i had AME shallen MX 19x9.5 +35 and 19x10.5 +30 rear ,and i was rolling low( no finger gap at the front and half on the rear) , but i was rolling on 225/40/19 255/40/19
12-09-09, 06:43 AM
a 255 on a 10.5 is pretty streched though on a 10.5" wide wheel correct?
12-09-09, 10:36 AM
IXI187IXI
Yep..........
LostS0ck
12-24-14 03:16 PM
tyacrzy
Suspension
02-22-13 05:11 PM
deca1234
12-21-10 02:48 PM
pandy_88
05-09-09 12:51 AM
Tank
03-29-07 04:51 PM
20 ,
2003 ,
20x85 ,
43 ,
95 ,
fit ,
gs ,
lexus ,
ls400 ,
offset ,
rims
