LS 460 stock wheels on GS 350?
Most of you will probably think I'm crazy, but I'm tired of 5-star wheels. Had them on my last car for ten years. My 2007 GS 350 has the stock 5-stars on them and while they look very good on the car, it's a sporty look, and I'm after a more luxury/classy look. Every time I see a stock LS with the 10-spoke wheels, I think it looks great.
I don't mind the stock 17" 10-spokes on the GS 300, except 17 is too small.
I'm a wheel noob... Would these LS wheels fit on my GS, and could I use the same tires (Yokohama Advan 245/40 R18)?
GS specs: ( http://www.sewellpartsonline.com/par....asp?id=180781 )
* Size: 18 x 8 inches
* Bolt Pattern: 5-114.3
* Offset: 45 mm
* Weight 29.65 lbs
* Accepts TPMS Sensors
LS specs: ( http://www.sewellpartsonline.com/par....asp?id=187268 )
* Size: 18 x 7.5 inches
* Bolt Pattern: 5-120
* Offset: 32 mm
* Weight 27.75 lbs
Have any of you done this or know where there's a pic?
The GS in this picture is what mine looks like. The LS wheels are cheaper than the GS wheels... so I can probably break even.
* Offset: 45 mm
* Weight 29.65 lbs
* Offset: 32 mm
* Weight 27.75 lbs
well, if you look at the bolt pattern, right away you should know it won't work.
but seriously? If both with the same pattern.. I will be VERY glad to give our LS460L rims away for your GS rims..
i hate the stock LS rims. looks so small and insignificant.
Hey, where are you located? Seeing the Sewell logo, I am guessing you are in the Dallas, Texas area?
I am looking for these rins to put on my 06 GS300. If you happen to replace them, please let me know and I will take them off your hands.
NG
NG
I had exactly same wish as yours and found this wheels on ebay. Many CL members has advised against it due to some good reasons. I am still thinking about it but most likely won't go for it.
Read this thread and let me know what you think.
https://www.clublexus.com/forums/gs-...gs350-awd.html
I'm in CA. My wheels aren't from Sewell... they just had a good pic of them. If I find the wheels I want, maybe I'll look you up!
