annoying plastic pop rivets..
What's the trick on getting those annoying plastic pop rivets out that hold down the engine dampening covers without breaking them??? Also, is somewhere to get some new ones ? ;-> (hopefully not from a dealer). My first attempt of getting them out was not successful at all...
Thanks!
Thanks!
there actually was a diy on these. like the others mentioned, press down on the center til it clicks then it just pops out. to install them, you have to open the end with your fingers and push the center piece back up. then just push it back into the hole when you put the cover on.
you can get the same size at any auto parts store. they likely won't be the center pin OEM kind but they'll perform the same function and be easier to remove/reinstall later
corradoMR2
04-30-17 05:03 PM
