Need Help with Light Bulbs PLEASE.......
Hey Guys
One of the LED wedge bulb (The bulb that is in the same housing as the high beam) had broke and that forced me had to switch back to the stock one for now. My question is that what kind of LED bulbs should I get? Is it these: http://www.v-leds.com/Exterior-LED/C...orLanding/true
And I have the Philips 6000K low beam highlight which one of them should match up better? And is there any other place people would recommend me to get these bulbs from? Please help me out thanks.
KY
KY
You should switch your (9005) DRL to LED too if you want an LED wedge. If you put a LED wedge, the heat from the halogen DRL causes LEDs to fail prematurely. If not, go with a whiter incandescent alternative. Polarg M4s are popular.
