Remote Source in Rear for Aftermarket Amp
Hi,
Just wanted to know if anyone knows of a good source for a remote wire in the rear of the car (GS350) to hook up an aftermarket amp. I already have power wire running along the passenger side door sill, and don't want to run another remote wire to the fuse box up front.
Thanks!
Thanks!
Hi,
Thanks!
Thanks!
I was considering running the remote wire along with the power wire, however I keep reading about how you're not supposed to do that due to the interference the power wire give off. Any thoughts?
uhh.... remote wire's made so that your amplifier won't draw power during the time your car is off, intertwining it with your main power source is a bad idea, at least in my aspect of things.... the fusebox in the back? i'm pretty sure one of those things runs to a power source... just don't tap it to something important like fuel pump or something hahaha, i'm not sure beause i haven't triple checked the fuses back there yet.... but i DO recall there being a rear fusebox
Ended up getting a PAC high low converter for 20 bucks and hooking it up to the rear sub for the source. Only hard part was making the leads from sub a little longer since they were so short after cutting the 4 wires.
VTLexus
06-27-08 08:40 PM
sxwk12
06-13-03 12:57 AM
