My gs wont start properly! (start button issue)
I have about 60k miles on my car. Usually, when i would step on the brakes and push the Start button, the car would start. However, recently, if i did that, the car wouldnt start. It would attempt, but fail. Now, i have to HOLD the button in until it starts. Everything else seems to be working fine.
is this a common occurance to anyone with a PUSH button start? or is there something wrong? Low battery or new ignition module?
I wonder if the ignition system is not picking up the key fob. I wonder if a new battery in the key fob will fix that. I had an issue when I first got my car where the car wouldn't pick up the signal and wouldn't start and sometimes it wouldn't even let me into the car. The dealership changed the battery 2 times and it helped for a little bit, but then finally ended up just replacing the ignition system under warranty
my educated guess is that it is not the problem of the key fob (changed its battery couple of months ago). It's detecting my keys....
its hard to judge because it is a push start, rather than the traditional Turn start.
U know how older cars, you need to turn and hold for little longer for the car to start? it kinda feels like that. Im just hoping, its something not major, and i just have to accept the fact that the car is getting old.
If you have to hold it down, you are "cranking" the engine. It's described in the manual somehwhere.
The reasons you would have to "crank" the engine, are the same for a push start car as any other car.
Some things would be:
- Weak battery not providing quite enough juice to the starter
- Bad alternator causing the weak battery
- Bad starter having a hard time turning over the engine effectively
- Fuel delivery issues (fuel pump) is not pressurizing your fuel system as fast as it used to.
its not too long... probably for 2 ~ 3 seconds. It felt like it was more than necessary Since before just push of a button would start the car.
Couple weeks ago, i did help my friend jumpstart his car. Could that be the reason why? Damn Mercury!
my friend's ls430's having a same issue as op. it will crank, but at least 5-7 seconds to start the car. first, he replaced battery.. second, the dealer diagnosed the problem as fuel pump, but didn't help either. i wonder if this is somehow related to exhaust manifold.
Wouldn't most of the things that will go wrong be "Basic" warranty things? I had an extended warranty on my last toyota and it didn't do me a lick of good even once. The first thing that broke that would have been covered by it, was like a month out of ECP.
When you push the start button and let go, its suppose to hold crank for something 10 or 15 second or until the car starts. If you let go of the button and the car stop cranking, there is a problem with either the start computer or some kind of sensor.
ill try to upload a vid of it. I can take it to the dealer, but its gonna cost me an arm and a leg just for them to inspect whats wrong with it.. and anohter $$$$$ just to fix it. But then again, i shouldnt have gotten a lexus then.. lol
