lighting question
Old 12-04-09, 11:51 AM
JMan604
JMan604's Avatar
Default lighting question
is the bulb on our inner headlight a 192 bulb? Im trying to find an LED replacement for it. I really hate the amber color of the stock bulb. Doesn't match our HID headlight.
Old 12-04-09, 12:27 PM
kyang91
kyang91's Avatar
I believe they are......they are also call the "wedge bulbs" they are pretty easy to find online. But there has been problem with the LED bulbs that can not withstand the heat from the DRL. So if you want to replace the wedge bulbs I recommend you change the DRL to LED as well.......
Old 12-04-09, 05:01 PM
manyvices
manyvices's Avatar
I'm in agreement with JMan. I actually went into Advance Auto last weekend and the salesman was actually telling me that I would need to buy a "kit". I'm not really sure what he was referring to, though.
Old 12-04-09, 05:08 PM
xmike714x
xmike714x's Avatar
DRL = daytime running lights
Old 12-08-09, 06:26 AM
nehal51086
nehal51086's Avatar
from what i know you wouldnt need to buy any kits....he probably doesnt know what your talking about, probably thinking you want to change the drl bulb to hid...all you would need is a new "wedge" or a 194 bulb...should just have to swithc them out...
just a heads up if you change your DRL to LED you will loose highbeams...maybe an option would be to have DRLs turned off, that way that bulb only comes on for highbeams...
Old 12-09-09, 07:29 AM
The G Man
The G Man's Avatar
And to run the DRL with LED, the LED would have to run on half power. Most LEDs will not run on half power and you will need to re-wire the DRL circuit.
Old 12-09-09, 07:39 AM
nehal51086
nehal51086's Avatar
just another reason why not to get LED DRLs...i ment to keep facotry bulb and just turn off DRL(if heat is a factor for the LED wedge bulbs)...
westwest
Lighting
12-16-19 07:15 AM
SweetWater
CT 200h Model (2011-2017)
11-29-17 06:22 AM
aristoboyy
11-17-15 05:29 PM
xbladex00
07-01-15 07:33 AM
ssjnimma
02-24-10 04:45 PM
Quick Reply: lighting question
