V-LED DRL brightness during daytime?
Not quite as simple as that but not too hard. You will need to remove the plastic cover on top. Find the extention for the bulb holder and just turn and pull. Whatever you do, dont drop the bulb in the light housing
One of the sticky up top have step to step direction with pictures.
The bulb holder pulls out both the DRL and the parking light bulb, or are there two rods?
i'm assuming the ones in Chancellor's pics are the 68 SMT DRL LEDs, right? For those who have it, does it look like disco ball in person? Or was that just an effect of the pics?
And to the OP, since you've been considering the 2x brighter DRL LEDs, i have a question for you (and anyone who's using the 2x brigher ones). It says in the description we'll need to use DRL module and HID relay harness. Does anyone know how many of each do we need? i'm guessing 2 of each? anyone know for sure?
this is what i used. the 2x smt bright leds and the 9005 module. im not going to lie but when i installed them it blew out my fuse which i then replaced with a higher one and to this day, that was 2 months ago, no problems
Kind of makes you wonder, though.
However, i asked v-leds twice about the 2x brighter LEDs, because of what mysteryan quoted from their website, but for some reasons they don't seem to understand my question as they really didn't answer my question. The first time i asked, they said only one module is needed, but they didn't say whether it's the relay or the DRL module. i don't feel like asking a third time
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Based on what the DRL module does (i.e. allow the LED bulbs to run at full power at all time), it would seem we would need a pair even for the 2x brighter leds? Is that right SRGS300? But apparently the 2x brighter ones require the relay harness to be safe, but not sure how many
