I'm thinking about adding a 5 or 10 mm spacers to my front wheels. Can I add spacers if the back of my wheel looks like the picture below? Not sure if there is enough clearance for the stock bolts that tighten up to the spacer.
Yes you can use a spacer, just not the bolt on spacers like Ichiba. You need the spacers with out the studs in them and you will need longer studs to use them. I would suggest to use them even with the 5mm spacer.
Check the classifieds as there is always a set for sale.
I have 5mm ones they don t have the hubcentric extension and i have no issues, the factory hubcentric ring may just be long enough to catch the center bore of the wheel, anyway they make lug nuts that have a 1/4 inch extention on them that will reach your bolt
