5mm spacer question
Old 12-29-09, 03:22 PM
lkapimp216
lkapimp216's Avatar
Default 5mm spacer question
is the factory hubcentric ring long enough to reach the center bore of the wheel when using a 5mm spacer? In other words does the hubcentric ring stick out off the hub longer than 5mm?
Old 12-29-09, 05:07 PM
rominl
exclusive matchup
rominl's Avatar
i don't have exact number, but i highly doubt there will still be enough lip after the 5mm spacer
Old 12-29-09, 06:17 PM
passnu2
passnu2's Avatar
OEM hub ring is not going to protrude past a 5mm spacer....the hub ring is all of 2mm maybe? If you get a 5mm spacer make sure its hub centric.
Old 12-29-09, 07:36 PM
lkapimp216
lkapimp216's Avatar
i ve called ichiba they dont have a hubcentric extention on the 5mm spacer the ones i have had on there and don t give me any vibration, i ve had it up to atleast 100mph riding smooth that is what inspired my question i thought that maybe the hub ring pretruded maybe 7mm or so just enough to catch the center bore enough to keep it centered
Old 12-29-09, 10:30 PM
designo
designo's Avatar
I would have thought any spacers would have a lip
Old 12-29-09, 11:41 PM
rominl
exclusive matchup
rominl's Avatar
nop, not all spacers have lips. that's why there are hub centric and non-centric spacers
Old 12-30-09, 05:42 PM
lkapimp216
lkapimp216's Avatar
Default oem centric hub ring
Does anyone know how far off the hub the oem centric ring sticks out into the center bore of the wheel
Old 12-30-09, 06:27 PM
passnu2
passnu2's Avatar
with out taking off my rim and measuring ~3mm or less. Its not much. What are you trying to do?
tmf2004
06-08-16 08:34 AM
trinituner
Wheels, Tires & Brakes Forum
10-10-13 01:12 PM
CleanCL
Wheels and Tires Classifieds
10-13-10 11:00 PM
supralative
SC- 1st Gen (1992-2000)
13
03-13-09 01:55 PM
sincityIS
Suspension and Brakes
12
02-19-08 04:33 PM
Quick Reply: 5mm spacer question
