Problem with Vais unit or head unit
I was driving today and decided to switch from listening to XM to listening to my iPod unit. I pressed the disc button, and it went to the DVD changer. I pressed it again to activate the CD changer mode, and it would not activate. I also tried to do it by voice command and that didn't work either.
Any thoughts?
Any thoughts?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Did you check to make sure your ipod is well connected and that the ipod screen displays the Vais logo?
However right now the iPod is just displaying the regular iPod menu screen which suggests that the iPod does not think it is connected to the Vais.
Try disconnecting the vais unit from the harness and then plugging it back in after 30 seconds or so. Could be that the unit is locked and can't reset while the car is supplying some level of power to it.
If that doesn't work just try leaving it disconnected and seeing if the head unit works properly without it. At least you can determine if the unit is fubar or not this way.
With my GROM unit, I locked it up trying a firmware update and this solved the issue for me.
Thanks guys. I will try using it with my iphone. If that doesn't work, I will take it to dealer when I get back to Florida. Dealer sold and installed the unit.
Okay, this problem is getting even more bizarre.
I have the same issue with my iPhone. Cannot put the headunit in CD-changer mode which is where the Vais iPod controls are.
But here's another odd thing. In any of the radio modes (FM or Sat radio) if I start playing a song using my iPod's controls, it will play through the head-unit and cut out the existing satellite radio signal. Then to get the XM back, I have to disconnect the iPod.
Any thoughts on this?
It is Vaistech. I called them to descive the issue, and they said the same thing you said. They said it needs to be rebooted and re-initialized. They suggested I go to the dealer that installed it and ask them to do it.
