Ichiba 20mm's & Eibach's Installed (Before & After Pics)
#33
designo, When you ordered your Eibachs, what part # did you get? I know they don't exactly support the GS460 so I was wondering which set you got of the Pro's
Car looks great btw!
#37
I don't think that is entirely true... If you look at the F-Sport in comparison to the Eibachs, you will see a difference. To my understanding, the Eibachs coils are spaced pretty even from eachother whereas the F-Sports have a tight wind at one end (much like the Tanabe springs).
#38
I was getting vibrations because the first set of 25mm spacers I ordered did not have hub rings, and the center bore of the spacer was slightly larger than my wheel bore size. Hence the vibration.
I then ordered ichiba 20mm spacers that had hub rings. Although they too were very slightly larger, I was able to have another hub ring fabricated to fit tight into my wheels.
The hub bore size should be exactly snug and tight fit to your wheel bore, otherwise you will get shaking and vibration.
saewoo
08-16-16 11:15 PM
ChitwnGS
General Classifieds
03-21-12 11:11 AM
ahohnstein
05-17-07 09:01 AM
ahohnstein
Wheels and Tires Classifieds
05-16-07 07:25 PM
