Hey a couple questions. Plz help
Old 01-10-10 | 12:38 PM
azimali's Avatar
azimali
Smile Hey a couple questions. Plz help
Ok so i'm new here and i'm about to join the Lexus club hopefully this week.(Totaled my Acura). I am twenty years old and live in Georgia. So i've been looking around the internet for a while and i'm a bit confused. As of right now im either getting the 07' LS460 or the 07' GS350. Its up to how deep he wants to reach into his pockets. Well im thinking about making my ride look nice and ive been looking up body kits. I saw a couple for the GS350 that I liked and are affordable, but for the LS460 im having trouble finding a body kit thats less than three grand. Also im thinking about buying a set of rims. Do i have to modify my car to be able to fit 20 inch rims on it. Lastly where can i have a body kit installed and how much will it cost. I'm not looking for executive level installation just installation and a little paint on the body kit. Thanks in advance. Hope to be here for a while.
Old 01-10-10 | 01:57 PM
greyhndfan's Avatar
greyhndfan
I recently installed a full carson body kit with lip, sides and rear for 700.00 included paint and install. I'm not from GA so can't offer any advice on where to go.
Regarding rim size and choice, depending on how agressive you want to be, you typically do not need any modifications to run 20s, but if you decide to drop than of course you might need to. Good luck on your search and take your time.
Old 01-10-10 | 03:01 PM
azimali's Avatar
azimali
Thanks that helps alot but i need someone who can give me a more solid number
Old 01-10-10 | 03:12 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
if done right, 20s won't have any rubbing
get a car and mods that you can afford, that's all i can say
Old 01-10-10 | 03:22 PM
azimali's Avatar
azimali
What type of store should I take my car to if I want a body kit installed. I know I shouldnt go to a dealership, but idk. I'm seriously lost.
Old 01-11-10 | 04:40 AM
ryan78's Avatar
ryan78
check out carsontuned.com. it's a good place to start. you just need to make friends with google, and start looking to see what is out there. as to instillation, reach out to reputable local shops. tuner shops would be a good place to start; they can reccomend good paint/installers.
Old 01-11-10 | 11:22 AM
Heng350's Avatar
Heng350
haha rominl is right lol... lexus mods are pretty expensive.
like the others have said. 20s will work with no modifications IF you dont drop the car. Usually you would have to roll or cut the fender if you do want to drop it. Tires play a big part in the rubbing game so get ur tire size right :P
Old 01-11-10 | 11:35 AM
LS4fun's Avatar
LS4fun
A good body shop should be able to help you take care of the body kit install, provide the necessary adjustments, as well as paint/blend the body kit. Shop around your area and get advice/recommendations on people that may have had experience with a similar install.
Good luck.
Old 01-11-10 | 11:58 AM
BinaryJay's Avatar
BinaryJay
I don't really understand why the wheel size has anything to do with it, as long as you are putting tires on that conform to the same rolling diameter of the original wheels shouldn't that be the only bearing as long as you don't get super wide rims?
Old 01-11-10 | 12:07 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
couple of factors. with 20s some people want more cushion and put on larger (out of spec) tires on their 20s and that can cause rubbing.
or sometimes people put very wide wheels in the front and with the tires, when making full lock turns, it can rub the front and rear part of the front wheel well
and of course, if the offsets are too aggressive, meaning the wheels stick out too much, then no matter what tires you put on, it can rub the fenders
that's why i said "if done right".
Old 01-11-10 | 12:52 PM
IXI187IXI's Avatar
IXI187IXI
wheel and tires are about 3 main things. tire size, wheel width and wheel offset. all 3 play a huge factor in what will rub and what will not rub
back to the op, no one can really give you a solid price on what its going to cost to paint and install a kit since every shop charges different rates and what not. your best bet is to call around.
Sinister66
09-16-17 06:16 AM
BLu_Gs3
03-10-03 11:28 AM
Uhcordvee6
IS - 1st Gen (2001-2005)
08-16-02 02:12 PM
