Help with removing the backing of the front seats
I'm sure this has been askedbefore but I can not find the answer using search. I am trying to remove the back pocket from the front seats and can not get them to come off. Besides just clips and the elastic straps under the seat is there anything else that holds them on?
There is a thread. Someone changed out the plastic parts, forget what they are called, in the front of our seats that's on both sides. They are plastic...
That member had to remove the rear backing to get to the screws to remove them. If I recall they just popped off but its been a while. Search for that thread and it should give you everything to help you out.
