Help with power mirror
Old 10-23-12, 05:11 AM
  #31
Ironman50
Ironman50's Avatar
Re warranty......at least for my 2008 GS 350......in Dec 2010 when Lexus had the spring valve recall they changed the warranty (for consumer confidence) to 6 Yrs or 100K miles.
I would think this would include this mirror problem?
I am correct here?
Old 10-23-12, 05:13 AM
  #32
IXI187IXI
IXI187IXI's Avatar
Originally Posted by B.Diddy
I wonder if they will issue a TSB for this? I find this hard to believe that the gears could strip that easily or does anyone know how to prevent the mirrors from auto tilting? maybe pull a fuse or relay associated with engaging reverse? I dunno.
if you use the drop down box by your left knee, you can select the mirrors for left or right. if you have it set in the middle (ie neither left or right selected), the mirrors will not tilt.
I am correct here?
thats power train, will not cover the mirrors
Old 10-23-12, 09:35 AM
  #33
B.Diddy
Lexotic Concepts
B.Diddy's Avatar
I ask a friend that is a svc advisor to check for me and there is no current or past TSB for the power mirrors on the GS350.
Old 10-23-12, 09:37 AM
  #34
B.Diddy
Lexotic Concepts
B.Diddy's Avatar
The problem is with the stripped mirror gears, even the positioning associated with your memory seat settings are now incorrect. This has been a nuisance for me for a few years well now, I am just shocked more people have had this problem. I thought I blew a fuse or relay or something.
Old 10-23-12, 07:19 PM
  #35
SirCrush32
SirCrush32's Avatar
I just notice that my 07 GS350 barely tilts down so I will be taking it to the dealership. I guess I'm happy I purchased Lexus Platinum Warranty so I pray it's covered.
I would like to know if I could get mirrors with the side markers if I pay the difference?
Old 10-24-12, 09:39 AM
  #36
caveman
caveman's Avatar
my 06 GS300 driver side mirror also stopped tilting down and i got it replaced under the platinum VSA, so yours should be covered.
if i remember right, the total [warranty] bill for the side mirror assembly replacement was over $700.
Old 10-24-12, 09:53 AM
  #37
SirCrush32
SirCrush32's Avatar
Thanks for confirmation I really appreciate it. I'm hoping I can go in one time and get a few things fix at once. Not noticing anything else but maybe the trunk.
Old 10-24-12, 10:03 AM
  #38
IXI187IXI
IXI187IXI's Avatar
no, they will give you the mirrors for that car. if you want the 08+ mirrors you will have to buy them yourself and install.
Old 12-11-12, 07:16 PM
  #39
fventura03
fventura03's Avatar
i'm noticing this issue, i've turned off the "auto-tilt" feature by turning off the lights in the drop down knee control panel, and that works, but when i lock my doors the mirrors move into some weird position...
everytime i get back into my car, i have to manually adjust my mirrors, any help on this? replacing my mirrors seems like a huge waste of money when everything else works (folding, moving mirrors, etc)
Pearlpower
09-04-22 03:25 PM
mykeeh33
07-22-20 04:58 PM
b2884987
RX - 3rd Gen (2010-2015)
04-22-19 06:36 PM
JoeKuhn
12-29-12 03:09 PM
dunnojack
08-12-09 05:07 PM
Quick Reply: Help with power mirror
