about my 2007 gs 350' head light
http://www.trademotion.com/partlocat...layCatalogid=0
It appears the headlamp assembly comes in parts with and without washer. I guess at some point the headlights were replaced in OP's car for some reason and they replaced them with the ones without the washer for reasons unknown.
You don't have that little rectangle on the bottom of the headlight yet you have a button in your console for the spray? That doesn't sound right at all. I wonder if it was in some kind of frontal collision like you feared, and they replaced (by accident perhaps) the chrome trim around the headlights with the wrong part number. I've never seen a GS here without that little gap though.
This is exactly what is happening to me!!!!
I just realized that. In fact yes, I have the button, and when I press it, it spills water, but since I have the "normal" headlights without that little gap it doesnt actually washes the headlights.
So, I have a couple of questions
- This headlight washer system , where does the water comes thru?
Thru a hole in the front bumper or thru the gap shown in the picture above?
-What happens if I buy a headlight unit with that little gap, should it fit?
-Every button u have in the little console at the left of the driver seat, means u have that option on your car? Or you can buttons like parktronic and AFS off and you actually dont have those options on your car?
Thanks people.
If it dribbles water then you have the plumbing and the feature, but it appears it's not hooked up to the actual nozzle that should be in the headlight. When it sprays, it comes out from the gap area as a mist just like the windshield sprayers.
You shouldn't have buttons for features you don't have. I don't have the pre-collision/radar cruise on my car, so that button is not there, but I do have parking sensors and the button is there.
Yes I have the parktronic button!
Anyway, it seems I got the wrong headlight assembly, I should have the headlight with headlight washer, I know that.
If I buy a headlight, it comes with a gap. (the gap where the water comes out)
Do I have to buy the headlight washer actuator sub-assembly as an extra part then, to fill that gap?
See picture attached
That is not an option. But thanks for the suggestion.
My remaining doubt is if I have to buy the headlight washer actuator sub-assembly as an extra part then? Which costs MSRP $275, just that little part LOL! Or not?
I am ordering the new headlight but not sure if I would need to order the other part also.
The only sensible answer, if you ask me, is to pretend that you don't have headlight washers and forget about it. Those of us that have working headlight washers don't even care.
Ok, Im happy to report an update, it may be useful to others eventually.
Bought the new headlight assembly.
And the little chrome gap where the headlight washer fluid comes out, doesn`t come with the headlight as I already knew.
The question was, where is that chrome piece missing? Where to buy it?
Well, it was underneath the bumper, at the top of the headlight washer sub actuator assembly.
Photo attached.
Photo attached.
I have a 2008 GS350, the base model, and I do not have the headlight washers. It only comes on premium packages (this is the case in Canada atleast.)
I have a button for the headlight washers inside but no nozzle outside.
