DIY: Parking light/ D4S HID low + Xenondepot 194 LED
Old 09-02-10, 08:11 AM
  #61
worker
worker's Avatar
Sadly I'm tired of replacing HID bulbs. So going back to OEM 4300K for longer use. I'll get 4500K fog to match.
Old 06-14-11, 12:08 PM
  #62
Dustoff
Dustoff's Avatar
Default Polarg M4 halogen bulbs vs OSRAM
Can someone let me know if I should get Polarg M4 or OSRAM to match my stock HID? And where I should get them from.
A lot of people asked how the Osram Cool Blue Bulbs look , so here is a comparison to stock bulbs
left in pic [OEM], right in pic [OSRAM]
[/QUOTE]
Old 06-14-11, 12:19 PM
  #63
worker
worker's Avatar
^ still look yellow to me. A lighter yellow but still yellow.
Old 06-14-11, 12:33 PM
  #64
BinaryJay
BinaryJay's Avatar
Originally Posted by CAK 500
I had the dealer turn off my drl yesterday. They were very reluctant until I pointed out that this is a dealer customizable feature according to my '07 GS350 owners manual.
They agreed and did it for free since I was having them install springs and do an alignment. I now drive with my parking lights on during the day; with the putco 360's effectively serving as my drl now. Looks just the way I wanted. Thanks Kevin for all of your research.
If DRLs are required by law where you are, I think you're still in danger as none of these LEDs - even the 1W Nichia ones I'm using right now - are bright enough to show as anything more than just a small bright dot of light in the housing in daylight.
I previously had those 360s and found they were even less bright but I didn't replace them because of that, I had a bunch of issues with parts of them flickering on and off.
Old 06-14-11, 12:44 PM
  #65
Kcook700
Kcook700's Avatar
If you wanna match your stock HID, check out these Philips LED wedge bulbs. Discussed on CL here.
Old 06-14-11, 12:52 PM
  #66
mag1c12783
mag1c12783's Avatar
Does anyone know how well the putcos fit in the plug? I tried to install the vled ones for my city lights over the weekend and they were so loose. They ended up falling into the housing when I was trying to put it back in.
Old 06-14-11, 01:32 PM
  #67
worker
worker's Avatar
Turn on headlight, problem solve.
Old 06-14-11, 10:40 PM
  #68
BinaryJay
BinaryJay's Avatar
I've had both the putco 360 and the newer putco nichia ones now. The 360s fit snug, the nichia ones since they have no plastic base and are just the circuit board fit with play in them side to side and I originally had some reservations about them but they have been in the car for a long while now and have been driven through nothing but really nasty downtown roads and they have been fine.
Old 06-15-11, 06:53 AM
  #69
Dustoff
Dustoff's Avatar
Thanks.. Great help.
Old 11-11-11, 02:04 PM
  #70
valyae
valyae's Avatar
Those Autolumination bulbs look hot. Are they "8K White", or "Blue"? Thanks.
Old 12-27-11, 08:48 AM
  #71
YUNGTETRIS
YUNGTETRIS's Avatar
Default DRL Led
Hello, I installed 194 360 via your instructions(which were awesome btw). However I was told I need a resistor, I was wondering do you know which one I need?
Old 01-17-12, 05:53 AM
  #72
tbilisi79
tbilisi79's Avatar
I installed these yesterday. and I love them. A bit bluer than I wanted them to be, slightly bluer than stock HID lights but still a lot better than factory.
If only I could disable those damn daytime running lights.
Thank you for write up. Was very easy.
Attached Thumbnails DIY: Parking light/ D4S HID low + Xenondepot 194 LED-photo-1.jpg
Old 01-17-12, 08:18 AM
  #73
j0emama
j0emama's Avatar
All you do is have to ask your dealer. They should do it for free as it's a whole 20 seconds of work for them.
Old 01-17-12, 05:03 PM
  #74
tbilisi79
tbilisi79's Avatar
Thanks!... Ill do this feb 2 when I go for oil change.
Old 08-10-12, 07:16 AM
  #75
AustinSBP
AustinSBP's Avatar
what kind of springs did you have your dealer installing?
Quick Reply: DIY: Parking light/ D4S HID low + Xenondepot 194 LED
