well i want to remove the emblems and on the side that says GS350 i will put a WALD badge there so one side should be fine ...but the side with the LEXUS...i am wondering should i take it off or leave it
If you replace the GS350 with Wald then leave "Lexus" on. I can't stand holes which is why I didn't remove my emblems...heard it cost a lot to have the holes professionally filled in too?
A little bit of bondo, touch up paint, wet sanding and a porter cable or a ton of elbow grease should be good enough shouldn't it?
