So, does this malfunctioning gas pedal system affect us or not?
My AWD has the hanging accelerator instead of the granny board. From what somebody else mentioned before, I think all AWDs have this kind of accelerator and the RWDs have the big old "board" type.
Here is an article which expounds my concern about the government behaviour on this:
http://www.investors.com/NewsAndAnal...aspx?id=520091
Right, the conspiracy theory I was referring to. I definitely agree that the US government should just get out running companies and go back to running the government and cutting the deficit. That's not a discussion for this board though.
Well, conspiracy theory or not, LaHood does have a duty to make sure the cars are safe.
In terms of being educated, i won't claim to know enough about the electronics that LaHood wants to investigate but if that is an issue and can also be or actually be the cause of the acceleration issue, then hinge design won't matter nor does the manufacturer of the pedal (CTS or Denso). CTS did say it manufactured the higes to specs provided by Toyota. If it is really a faulty manufacturing rather than faulty design, then Toyota should sue CTS to clear their name. It would be interesting if they don't - perhaps CTS is too important for Toyota to go after....don't know.
My 2004 GS 300 has an acceleration problem but not the one in the recall.
It began around 6k miles and has been chronic ever since. Every time I take it to the dealer I note it on the ticket and every time Lexus tells me that Toyota is aware of the issue but there is no resolution, recall or computer upgrade. They told me it seems to be an issue with the ECM, transmission and drive by wire.
The issue occurs when pulling out or at low speed. From stop press on the accelerator and the car moves about 25 feet then it slows up. The natural reaction is to give it more pedal then you take off like a rocket. At low speed below 45 it does not respond to the accelerator then surges ahead.
Countless times I've had to mash it to the floor to avoid an accident. Only solution found so far is pulling the EFI fuse after every oil change but it eventually shows up when you least expect it.
Seems their solution is to buy a new car. I submitted a compaint to the NHTSA and have found the same issue on line. Lexus dealer brushed it off the last time and I told them I would own the dealership if it wasn't fixed and it caused an accident. They stopped smiling.
Guest
Posts: n/a
Thanks
Anyways, I hope Toyota is really trying to figure it out and regain consumer confidance in their products. Granted much of the hysteria has been caused by the witch hunt but that's Obama and his adminstration (and his GM).
I think most people realize that Lexus is not included in the recall, but I can see people questioning the Lexus engineering too since it is designed by toyota afterall. Also, I can see Lexus owners being concerned if the issue is as pervasive as faulty engineering with the electronics. I can't imagine that wouldn't affect Lexus cars at that point.
Lexus is included, Look at the 07 ES 350 that were quietly repaired.
I just took delivery of a new BMW 328 Coupe. This is my 3rd, and probably not my last. However, I bought a new '07 GS350 and it's been problem free. Realistically, from a reliability standpoint, the Lexus will in all probability outlast the BMW. I realize and appreciate the attributes of both. I will in all likelihood replace the BMW again (and maybe again) before the Lexus ever needs replacement. But I've always loved the ride and handling of the BMW, and don't want to be without one.
Bottom line - I've loved BMW's for the past 15 years, and will hopefully continue to do so. But, I anticipate always having a Lexus GS (if mine is any indication) if only for the fact that it's such a 'perfect' machine.
recall for the ES is the floor mats...not the accelerator pedal problem.
again though..this is a 3GS forum.
As far as the official word from Toyota goes, no. However, there seems to be some stories of the acceleration problem creeping up in Toyota cars that weren't included on the list. Also, there seems to be a larger investigation of the electronics. I would say if there is a problem with the electronics, I wouldn't be surprised if Lexus and other Toyota cars would be included.
I think it's more of a wait and see. Certainly not worried at this point. It's a little disappointing to see these issues coming up for Toyota. I wonder if they can ever recover on their reliability reputation. Has it been completely lost to Honda....
Hysteria is right. You have a better chance of getting struck by lightening than having your Camry go bezerk and start mowing down random pedestrians while you flail frantically at the wheel.
Anyone old enough to recall the Audi 'SAI' brouhaha of '86-87? First, 60 minutes did a hose job on them, by jury rigging a 5000 to with some high pressure hydraulic hose in the tranny (3sp auto
) Then the lawyers started smelling money. Then the owners started filing class-action lawsuits. End result? The NHSTA determined that EVERY incidence was due to "Driver error, pedal misapplication". Yes, Joe Boatfoot and Betty Twinkle toes were stepping on the gas not the brake. They pushed the pedal right to the floor, and still Audi would not stop! Uh, yeah, it was the Gas Pedal.
I don't know how much damage those things could have done, that old inline 5 had maybe 110 hp running through an ancient 3sp slushbox. I had one, bought it for $4000 used. nice car. Rattly dash though...
