Driver side mirror not going up or down?
Old 02-05-10, 09:28 PM
LeXuSrAcIn
LeXuSrAcIn's Avatar
Default Driver side mirror not going up or down?
My passenger mirror works fine. The driver side mirror can move left and right but not up and down. I know changing the mirror would solve the problem, but is there any DIY to fix this? Even if I could somehow lodge the mirror in the position I want would work since I'm the only one that drives it.
Old 02-05-10, 10:34 PM
XxGoKoUxX
XxGoKoUxX's Avatar
no, you most likely grinded a gear... and the gears are plastic... what I would do, is source down a shop or something, to see if they can replicate that broken gear in a metal version, at least that's what i'm going to do when mine's breaks
Old 02-05-10, 10:45 PM
THE.K.W.C
THE.K.W.C's Avatar
im having the problem with my driver side mirror not going up
Old 02-05-10, 10:53 PM
dmjay
dmjay's Avatar
if you have warranty still, take it to the dealer
Old 02-06-10, 08:17 AM
EyeKutr
EyeKutr's Avatar
i think this will be more trouble than its worth.....new used one of ebay for me when its time.....I should never need it since my mirrors dont fold up or down, in or out and I rarely adjust them for this exact purpose
Old 02-06-10, 10:29 AM
worker
worker's Avatar
anything moving will eventually "die".
Old 02-06-10, 11:25 AM
enigmaos
enigmaos's Avatar
"wear and tear", but for $50k cars, it should have been made with a better material to prevent premature wear.
Old 02-06-10, 12:41 PM
Arantant
Arantant's Avatar
Yeah, I turned off my auto-tilt reverse feature after already having both mirrors replaced once under warranty. Now I only turn it on when I parallel park on streets with curbs which is only a few times a month... same thing with the fold in mirrors; though i don't think anyone's had problems with that gear yet.
Old 02-06-10, 12:50 PM
tromly
tromly's Avatar
^^^^1, that's the first thing I do with all my Lexus, the auto-tilt feature will wear out the gears fast
Old 02-06-10, 02:00 PM
worker
worker's Avatar
or maybe install one of those round mirrors? no movements.
Old 02-07-10, 07:05 PM
THE.K.W.C
THE.K.W.C's Avatar
WWWWWHHHHHHAAAATTTT!!!!! I did not know I could just do that how can i turn it off?
Old 02-07-10, 08:05 PM
JRandall
JRandall's Avatar
Open the drop down with the mirror adjustment buttons. Press the L or R side of the mirror adjustment that is currently light. Now neither side of the button should be lit, and the mirrors will not adjust when the vehicle is in reverse.
Old 02-08-10, 08:32 AM
THE.K.W.C
THE.K.W.C's Avatar
jezz no wonder like 4 months ago I couldnt figure out why they would not tilt lol thanks. It was like -30C out side yesterday abd i didnt want to go into my car to get the manual
Old 02-08-10, 08:35 AM
IXI187IXI
IXI187IXI's Avatar
doesnt matter, its cheaper to make out of plastic so thats what they do. we have a 60k printer at work and all the gears are plastic too and they always break.
Old 02-08-10, 12:27 PM
lexlovgs
lexlovgs's Avatar
I had a same issue. My passenger side mirror does not go up and down. I performed mirrors and windows reset procedure and it started working fine.
I forget how to reset but search the forum, you will find it. try this before you spend money to get a new one. Hope this helps.
Quick Reply: Driver side mirror not going up or down?
