iSimple iPod interface
Old 12-05-10, 06:31 PM
  #76
bigblack06
bigblack06's Avatar
Originally Posted by lhayes518
I was told the same thing and had it installed at a car audio shop and it works but not perfect. Radio names showed up than disappeared. If i pressed the buttons on the screen to fast the unit restarts it's self. Also if i shake the wire attached to the ipod i hear loud static sometimes. I am going to get it checked out this week hoping maybe something wasn't installed right. One thing i must say it sounds good as hell on my ML System...
sad to say i'm still decid. whether to spend the money on the Vais Tech or get this iSimpe but thats good to know!
Old 01-09-11, 06:10 PM
  #77
IronCobra
IronCobra's Avatar
Where does the Isimple brain install? I have a 07 sat ready gs350 with sharkfin. It is truck mounted or do you have to remove the nav unit?
Old 01-10-11, 01:19 AM
  #78
bigblack06
bigblack06's Avatar
I'm pretty sure it was like the Vais Tech where the nav unit needs to move so you can get to the back!
Old 01-10-11, 07:03 AM
  #79
IronCobra
IronCobra's Avatar
I was guessing that, however, some are claiming a 10 minute install. I've done the Vais install and I guess I could have done it in 10 minutes, but it's more like a 1 hour install if you are being carefull.
also,
I want to use the iSimple gateway for Sirius. I have a GS350 with the Sharkfin and AM-SAT button. Do I need the Sat receiver as well as the iSimple or does the car already have the Sat Receiver built in?
Basically, what all do I need?
Thanks!
Old 01-10-11, 07:39 AM
  #80
bigblack06
bigblack06's Avatar
also,
Thanks!
Yes you need to purchase the additional add-on for the Sat, but can't you do the same with the Vais Tech by adding another addition to use it with!
Old 01-10-11, 11:43 AM
  #81
kahuna2
kahuna2's Avatar
Batman,
I have two of these kits installed in my two GS350s. Both kits were bought from TSS Radio, and installed by Audio Express in Arizona.
The kit contains Sirius satellite box, iPod interface/charger cord, and a gateway box (including all harnesses.) Each costs $229 with free shipping.
Once installed, you'll have normal iPod music functions (play, stop, fwd, back, random shuffle) as well as up to 10 character display (for 2006) and up to 20 characters (for 2007 onward) on your nav-equipped Lexus. Similar display feature for the Sirius box, and you can store up to 18 preset stations.
Your Lexus must have the AM/SAT button on your Nav unit for direct interface.
Now, I have my full iPod music library as well as Sirius whenever I'm on the road!
Good luck!
Originally Posted by batman75
Can you share any screenshots?
Can you navigate by Album, Artist and Playlist?
Is the wire in the glove box or inside the armrest compartment?
Did they insulate the box to make sure there are no rattles?
Old 01-10-11, 11:45 AM
  #82
kahuna2
kahuna2's Avatar
Please see my response to Batman as well. Your shark fin antenna is for your AM/FM reception only. The iSimple kit will have a separate Sirius antenna, which needs to be placed somewhere in/on the car. I have mine placed inside the back window, below the third stop light.
also,
Thanks!
Old 01-10-11, 04:21 PM
  #83
bigblack06
bigblack06's Avatar
I thought that antenna was made for the sat use and the antenna was in the back glass!
Old 01-10-11, 05:41 PM
  #84
rominl
exclusive matchup
rominl's Avatar
correct, normal am/fm antenna are both on the rear windshield.
the shark fin is for xm (from factory) technically, nothing else. otherwise those 06 without shark fin they are in big trouble
Old 04-30-12, 07:45 PM
  #85
batmbl
batmbl's Avatar
Default Pandora
Originally Posted by jonnyxboi
has anybody tried using the pandora app to play through the speakers?
Pandora works just fine. Great product.
Old 04-30-12, 08:08 PM
  #86
batmbl
batmbl's Avatar
Originally Posted by *Batman*
I went to get this my parent's es350 today, but all atlanta area best buys are sold out. The website is sold out too.
What model for the LX 470?
Curated Content Editor
12-17-18 04:15 PM
joedaddy1
07-01-18 05:47 PM
LVB
01-04-18 12:35 PM
aldousmh
ES - 5th Gen (2007-2012)
26
05-13-07 05:59 AM
S55inPA
11-10-03 01:41 PM
Quick Reply: iSimple iPod interface
