Easiest D.I.Y. MOD in 10 Minutes
Here is one of the easiest thing you can do to make your GS stand out, convert turn signal into parking light too!!!
This is what you will need to do this mod:
- one pair of 7443;
- 1.5 ft x 2 of 18 or 20 gauge wire;
- 3 ft of solder wires or cloth hanger; I used solder b/c is soft and flexiable it would not scratch the headlight housing;
- sharp knife;
- drill;
- electric tape.
If anyone is interested, I will write up a step by step instruction.
FYI, currently I am dealing with one of the LED maker, to see if they are willing to custom make 4500k~5000k LED bulb to match our Lexus. So for now, I am back with OEM yellow bulbs...
- one pair of 7443;
- sharp knife;
- drill;
- electric tape.
No, you do not loose the turn signal function.
The bulb we used for our turn signal is 7440, only has one filament.
7443 has two filaments, thus one for turn signal (21watt) and other for parking light (5watt). So even when you have the parking light on, and turn signal will out shine the parking light.
Yes, same concept and procedure. Just be sure to get the bulb that has two filaments if you want it to function as parking light also.
I did that during my lunch break, I will take them apart tomorrow and snap some photo...
Patience my friends, I will post the instructions tomorrow!!!
My friend is using thes leds http://autolumination.com/switchback.html so it's white when parking light is on and flashes amber when signaling.
"Note: Load Equalizers or a special flasher may have to be added to restore a normal blinker rate if switching a turn signal bulb to an led."
Did he have an issue with this?
Here you go guys, as promised !!!
Have fun !!!
Stevie
P.S. I used an old 7443 bulb to show how is done, new bulbs has already been installed in my toy!!!
Going off topic here...
I thought my wedding was pretty cool back in 1999 (we were both still in college at the time), 18 7series and 18 S-class... till my friend showed me this: http://www.funenclave.com/reality-bi...tml#post331720
Have fun !!!
Stevie
