Sl2s & sl2xmt
Could someone explain this product to me...I have a 2009 GS350 without the ML but with the navi and no satellite radio at this time. I understand I would need to purchase the SL2S box and sirius radio tuner box...but do this product utilize my shark fin antenna or do I need to purchase one of those crappy black things you see on peoples car? I guess I just want to know if this is a plug and play set up or is it a really in depth process to set up??
no, it's not using the shark fin, like you said there will be the extra black antenna that goes with the unit. it's all plug and play still, but you got the magnetic antenna to mount somewhere
if you want "factory" look and utilize the shark fin, you can always do the factory xm radio tuner kit
First of all, it will not be the SL2XMT unit, which is designed to hook up non-Lexus XM radio tuner. There is a separate model for Sirius tuner hook-up.
In all you will need three items: VAIS or another after-market Sirius tuner, VAIS SLS or whatever the current box for hooking up Sirius is, and SL2i. The three units will be daisy-chained: the Sirius unit in the trunk will connect to SLS, which will connect to SL2i, which will connect to the back of your head-unit.
You cannot use the sharkfin antenna since it has a proprietary connection for the OEM XM unit. You will have one of those black magnetic mouse-looking antennas probably on the front lip of your trunk.
By the way, I recently had SL2i installed in my car and I really love it. I now have no desire to sign up for satellite radio again despite previously being an XM subscriber and big fan for the last 7 years. Are you sure you will really need both the iPod adapter and satellite radio?
if he wants satellite radio, then
sl2xmt for xm
sl2s for sirus
and if he wants both sl2i-up and sl2s, the tuner is not daisy chained together with the two systems. only the brains (sl2i-up and sl2s) are daisy chained together, the tuner / antenna is unit you hook off the sl2s
Club Lexus Vendor
You can also daisy chain SL2s with any of our iPod adapters to get iPod integration as well.
You buy the tuner and the fitment kit off the Web very cheaply, and you install it yourself in the trunk. It is very easy to do.
