Inadequate GS Seat Warmers Solution?
Old 02-26-10, 10:01 AM
MelYW
MelYW's Avatar
Default Inadequate GS Seat Warmers Solution?
All, I have been very disappointed with the lack of heat my seats generate. As someone else put it, I think my rear gives off more heat to the seat than the other way around....especially with the cold MN winters.
Recently, I have been selecting the PWR mode when driving and my seats and in cabin temp increased rapidly. This probably happened since the car operates at different gear ratios and as a result generates more heat.
This may negatively impact your MPG while in the mode...but not quite sure if there is conclusive evidence to support this.
My experience is that it does but fractionally....all I know is that I have found a reliable way to increase the heat to my seats in a meaningful and consistent way.
Old 02-26-10, 10:12 AM
Yang1815
Yang1815's Avatar
Interesting. Thanks for sharing.
Old 02-26-10, 10:32 AM
BinaryJay
BinaryJay's Avatar
Well the seat warmers have nothing to do with the coolant temp. I can see the coolant heating up more rapidly in PWR mode, and therefore the heat coming out of the air vents getting hotter faster but other than that I'd say it's a placebo.
Old 02-26-10, 10:38 AM
IXI187IXI
IXI187IXI's Avatar
agreed with Jay. the seat warmers do not have anything to do with the engine.
Old 02-26-10, 11:14 AM
MelYW
MelYW's Avatar
It would be a placebo if the engine temp has no connection to the cabin temp, but as you pointed out it does.
Again, my hypothesis is that the PWR gear ratio creates more engine heat (transfered to the radiator/heating core) that is translated to heat for the heating system to draw from.
Do believe that the hotter air from the floor ducts then is forced through to your seat...resulting in hotter seats.
Either way, again, seems to work for me....early results are that the difference is substantial (for me). Just glad I am able to shorten the time I am freezing my A_ _ off here in MN.
Old 02-26-10, 12:29 PM
ivanz
ivanz's Avatar
The seat cooler is even worse...it doesn't work on mine at all when I sit in the drivers seat. It only barely works on the passenger seat.
Old 02-26-10, 01:16 PM
BinaryJay
BinaryJay's Avatar
I recall a thread a while ago about the seat warmers where they said after 2006 they changed them somehow for the worse.
If indeed the seat warmers don't use heating coils (as in 2006) and use something else, perhaps the air heater, then for sure hotter coolant will lead to hotter seats. BUT, there is no way that even if this is the case that their maximum hotness will be any different than maximum hotness outside of PWR mode... unless for some reason your coolant temp reads hotter in PWR mode than not, in which case, something is wrong!
In 2006, your seats will get warm even if the engine is off.
Old 02-26-10, 01:33 PM
arnieosp
arnieosp's Avatar
I have my PWR button "on" all the time, but my seat heaters suck anyways.
Old 02-26-10, 06:23 PM
I8ABMR
I8ABMR's Avatar
It was 68 degrees on the way home at 5:30 today. I love AZ. In the end the seat warmers don't ever get used. EVER. The cooling feature I use in the summer but like you heat issue I don't feel like the cooling feature is adequate as well. I complained when I had the car serviced and they said they "cleaned out the filter". It still not working like it did when the car was new. It is what it is. The AC is pretty adequate
Old 02-26-10, 06:49 PM
SRGS300
SRGS300's Avatar
weird. my cooling works perfect. i put my hand on it and i feel the air. as for the seat heater it is pretty adequate.
Old 02-26-10, 07:21 PM
R.DUB
R.DUB's Avatar
the seat heaters in the GS3 is much better than the GS2 heaters
Old 02-26-10, 07:24 PM
SRGS300
SRGS300's Avatar
no way.. my *** used to fry in my GS2 compared to my GS3
Old 02-26-10, 11:30 PM
XxGoKoUxX
XxGoKoUxX's Avatar
do you guys not max out your incabin tems on the auto function? some days i get 30 degree whether, and within 5 minutes i'm sweating big boy ***** all over the place.......people next to me at a stop light give me weird looks because i'm sweating in 30 degree weather LOL
Old 02-27-10, 07:18 AM
jtrue28
jtrue28's Avatar
hmmm. my seats get warm fast, and they're also warm way before hot air comes from the duct-work. if they don't have coils...I have no idea how that is possible. also, I was under the impression that the GS only has "ventilated" seats for cooling. meaning there is no cooling, it's just blowing out air. there is no air coming from the seats on hot...that seems to me that it would be coils and not heat from the blowers. YMMV
Old 02-28-10, 08:15 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Personally keep it at 66-67F (id take it down to the high 50's if it allowed me too). Thats pretty warm borderline overkill when its 20F outside.
Quick Reply: Inadequate GS Seat Warmers Solution?
