VERY carefully hahaha seriously it's not bad just rubs slightly on weird angled turns depends if the roads bumpy but overall it's good... No cup kit will be running one soon though
did you raise it because your were rubbing on the fender or fender liner? I need to tackle this when it gets warmer. Going to the OEM rims for winter saved me with the weak offsets.
Mike it rubbed on both fender liner has a hole already and is rubbing at a metal bracket im assuming its where the fender bolts to the bumper ill try to get some pics when i take off the wheels and rubs at a tab towards the front where its not rolled ( the spot where the bolt mounts for the fender trim black strip ) all you would need to do is shave the fender flat so that there is no more lip showing.
