D'oh! Sunroof Not Working Properly
Well this past weekend was fairly nice out so i decided to give the GS for a bit. Had the sunroof open no problem but when i went to close it became a problem. The sunroof gets to about 85% closed (to where the black metal bar is up front) then just stops and slides back open. Thought it was a little odd so i tried it again and again. Same results. I realized that if i hit the close button right before the bar to make the sunroof stop moving, i can tap the closed button about 3 to 4 more times to manually close it. Not quite sure what the problem could be and really dont feel like going to the dealer because it seems like it is something fairly simple. It does not make any strange noises or anything out of the usual. As anyone else run across this problem?
Things I would try/check:
1. Make sure the tracks are greased up and there isn't some small particle on the track. Almost sounds like the safety feature is kicking in?
2. If 1 doesn't help then I would disconnect the battery so you can reprogram the sunroof as if you lost power to see if that works.
reprogramming it should work. i had a similar problem. my "open/close" did not work but the "up/down" did. when i pressed slide "down," it went down further than the roof of the my car. i just reprogrammed it and voila. goodluck!
yea ill have to disconnect the battery and try to reprogram it. i tried to relearn it already without disconnecting the battery but it doesnt work.
i would take it to the dealer but im out of warranty already (52k) and it really seems like something simple. if i cant figure it out, ill ask my tech before i bring it in.
I hope a simple reset does the trick for you. It's amazing that something as "simple" as a moonroof can get so out of whack that it needs reprogramming. I mean, hasn't identical moonroof technology existed on cars for 20 years now?
Thanks!
i didnt have to disconnect the battery. it just started working again lol. i did run my fingers along the track to make sure there was no debris anywhere. i dont know if by doing that i picked up a little bit of debris that was stopping the sunroof from closing or not but it works properly now and i havent had a problem since.
CrackerJac
12-23-23 08:53 PM
