GS350 vs IS350 engine differences?
Old 03-10-10, 12:38 PM
mrsandman
mrsandman's Avatar
Default GS350 vs IS350 engine differences?
Are the engines for the GS350 and IS350 identical? 2GR-FSE is the engine number for both cars. Is that correct? I'm trying to find compatibility for engine parts/internals.
Old 03-11-10, 06:46 AM
MadMax96
MadMax96's Avatar
According to this they're the same:
http://en.wikipedia.org/wiki/Toyota_GR_engine#2GR-FSE
Old 03-11-10, 07:03 AM
LexFather
Guest
Posts: n/a
Identical they are!
Old 03-11-10, 08:51 AM
MelYW
MelYW's Avatar
Wow, what is the weight difference between the two? Are they geared the same to generate the same torque and HP output?
Old 03-11-10, 12:54 PM
bs0dxi
bs0dxi's Avatar
GS350's engine produces 303 HP but I had thought IS 350 is like 335hp? can someone verify?
Old 03-11-10, 12:57 PM
MadMax96
MadMax96's Avatar
Edmunds.com says 306hp on the IS. The difference could be how the intake and exhaust is designed in each car. The GS could by shy a few ponies in comparison due to an exhaust that yields a quieter sound or something.
Old 03-11-10, 12:58 PM
bs0dxi
bs0dxi's Avatar
ah ok. thanks madmax.
Old 03-11-10, 01:26 PM
ivanz
ivanz's Avatar
The GS 350 reaches top HP at 6200 RPM vs 6400 RPM for the IS 350.
Old 03-11-10, 08:36 PM
MIAMIGS3
MIAMIGS3's Avatar
good info , I've always wondered .
Old 03-11-10, 09:06 PM
alwayzspeedin
alwayzspeedin's Avatar
the gs350 is 303 hp and the is350 is 306 because of the flux capacitor connected to the intake side check under your spare tire you will find a flux capacitor under there...i never looked but if any of you do please take a pic and post
Old 03-11-10, 09:57 PM
TWong350
TWong350's Avatar
Dang it! I've always wanted a flux capacitor. I knew I should've splurged!
Old 03-13-10, 10:35 PM
Faraaz23
Faraaz23's Avatar
Are they calibrated differently at all? If you test drive both back to back, the IS350 moves out with urgency. Even taking the added weight into effect, I was surprised at how much less responsive the GS350 feels.
Old 03-14-10, 07:31 PM
jjscsix
jjscsix's Avatar
I haven't driven a IS in a few years - right after that model came out. But I'm damn impressed with the GS. It's easily as fast as the Infiniti M45 I had a couple of years ago, and a lot faster than the CTS I just got rid of.
Be sure you are running premium gas and have the ECT switch in the performance mode.
Old 03-14-10, 10:38 PM
I8ABMR
I8ABMR's Avatar
GS350-----303hp
IS350-----306 hp
335 hp for an IS350?????? This what they will need to do to take the HP crown from Infiniti.
Old 03-14-10, 10:40 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Yes they are identical. The 3 hp difference between the GS and IS is negligible. The physical difference is that the GS' upper airbox piece is shaped a little differently than the IS' for clearance. Otherwise, the lower portion of both airboxes are identical.
Quick Reply: GS350 vs IS350 engine differences?
