DESPERATELY need help with REAR brakes ('07 GS350)
got no where.. my rear calipers do not slide as they should and i believe i my slide pin is seized so i made an appointment with lexus for next thursday night. now my car is out of the original factory warranty (59k miles) but i did purchase the extended lexus platinum warranty (3 yrs, 100k miles) so i dont think i will have an issue but i will bring a copy of Special Service Campaign 9LB with me. i will let you guys know what happens. thanks for all the help ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
lets hope i dont have this issue but thanks for the suggestion
update to this thread...
i took my car in on thursday and sure enough my calipers were seized. when the dealer called me to tell me this, i was told that they were not covered under SSC 9LB since they adressed the recall by replacing the dust boots a year ago. they told me that since they were not seized last year, the issue with my calipers now would be my responsibility. when i mentioned the extended warranty i had, they took care of them, no problem. otherwise, that would have been $1k out of my pocket
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Did you have original pads when you brought it in? Also were ure rear calipers painted? i have the same problem when ill go in for an oil change ill see how they are if they are bad i am going to bring it in for service but i am scared that i used akebono brake pads and i painted the caliper's.
