SoundLinQ2 (SL2Vi) - iPod Video Interface Adapter
Old 04-11-10, 10:04 AM
kitphat
kitphat's Avatar
Default SoundLinQ2 (SL2Vi) - iPod Video Interface Adapter
i have a 06 gs300 non navi. wanted to know if anyone has put this in their car and see if its worth ordering? Also will it play video on my deck too?
Old 04-11-10, 10:24 AM
EyeKutr
EyeKutr's Avatar
I recently installed it for a member, if you do the dvd and nav bypass, it will indeed play video. Works well. If you order it, I can tell you what you will have to do, basically you to the yellow wire mod and cut the pink wire, see the link in my sig
Old 04-11-10, 11:24 PM
rominl
exclusive matchup
rominl's Avatar
i have recently done an 06 gs without nav as well with sl2vi, works very well and video plays great like eyekutr said
Old 04-12-10, 09:32 PM
kitphat
kitphat's Avatar
I found another kit for cheaper. It's called the toypd2. They say it's the same as the vais kit but the toypd2 is way cheaper. Anyone care to comment on the toypd2??
Old 04-12-10, 09:52 PM
kitphat
kitphat's Avatar
Ey rominl did u have to hook up the switch too. Cuz I have a 06 non navi gs too or is it just plug and play for us??
Old 04-12-10, 10:41 PM
EyeKutr
EyeKutr's Avatar
you wont need a swicth, but you will have to cut 2 wires....the unit itself is plug and play, but you have to fool it to think the car is not moving and parking brake is on....hence 2 wires are cut
Old 04-12-10, 11:08 PM
rominl
exclusive matchup
rominl's Avatar
http://www.vaistech.com/products/unath_res.php
^^^ this will answer your question on the toypd2 thing
also, it's only audio and doesn't have video like the sl2vi
like eye said, it's plug and play, but if you want to have full controls and enable video when car is moving, you either need to do wire cutting, or you need override kit. i have override kit
Old 04-13-10, 10:55 AM
kitphat
kitphat's Avatar
How much was the override kit?? And where can I get one??
Old 04-13-10, 11:28 AM
rominl
exclusive matchup
rominl's Avatar
for me i got it from ps, chung@prestigioussociety.com
it's not cheap, it allows you to use the nav and enable video when driving, all plug and play so it's safer. but a lot of members do the wire cutting and put in a switch.
Old 04-13-10, 03:55 PM
EyeKutr
EyeKutr's Avatar
he wont need a switch for his bypass, in fact his is the easiest bypass since he has no nav or ML
Old 04-13-10, 08:21 PM
kitphat
kitphat's Avatar
So I don't need a switch?? I just plug and play the vais??
Old 04-13-10, 10:30 PM
rominl
exclusive matchup
rominl's Avatar
oh he doesn't have nav, i missed that part, sorry. then in that case, just gnd the parking break and cut the speed sensor wire and that should do it?
kitphat, vais is always plug and play, but what eye and i are talking about is how to enable video and song info when you are driving
Old 04-13-10, 10:32 PM
EyeKutr
EyeKutr's Avatar
Exactly Henry... just gnd the parking break and cut the speed sensor wire ....
Rudy
Old 04-13-10, 10:41 PM
rominl
exclusive matchup
rominl's Avatar
Rudy
yeah, for non-nav cars, i think that's probably the easiest way.
Old 04-15-10, 02:16 AM
XxGoKoUxX
XxGoKoUxX's Avatar
took me 15 minutes to do my whole car from start and finish of the install... very very easy =] you just look at the wires, cut'em and ur good to go =]
Quick Reply: SoundLinQ2 (SL2Vi) - iPod Video Interface Adapter
