HID Issue, NEW to GS
Just bought a 06 and the left headlight turns off after a few minutes or Right side... The Fogs are HIDs aswell i doubt thats the issue tho..... Im thinking old bulbs or needs Capacitor????
Whats stock hid on GS300 ? should i go with 6000K?
On my S-Class Benz and i had to use the HID Capacitor so i didnt get flicker/turn off's and codes... With aftermarket HIDs on a GS do i need Capacitor??
Well, you're saying that both the left and the right headlight turns off. This does not sound like a bad bulb to me. Does this problem only occur with the fogs on ?
I have HID fogs as well, and all I did was changed the fuse to 15amp. I did not have to add anything else.
Stock is 4300K, 6000K would look nicer.
I have a 06 gs and am experiencing the same issue. The left or right will go out. If i turn off the headlights and then turn them back on the issue will go away for a bit.
Were you ever able to get this solved? I don't have the fogs on when this is happening just the headlights.
MR LEX NY
02-03-06 11:08 AM
Hameed
Lighting
05-10-03 12:36 AM
