Just had the clear bra installed but have problem
Old 04-18-10, 02:17 AM
ashley1977
ashley1977's Avatar
Default Just had the clear bra installed but have problem
I've just had the clear bra installed today by Advance Auto Engineering at Alhambra. They finished around 10pm it was so dark and I didn't check well. When I got home I found some problems, like because the clear bra kid is pre cutted so there is a big gap not covered near parking sensor, also at lower grill corner clear bra is lifting......could someone tell me is this normal? I just had bad installation? Or am I too picky? Thanks.
Attached Thumbnails Just had the clear bra installed but have problem-dsc00951.jpg   Just had the clear bra installed but have problem-dsc00954.jpg   Just had the clear bra installed but have problem-dsc00956.jpg   Just had the clear bra installed but have problem-dsc00947.jpg
Old 04-18-10, 03:02 AM
GS350Lexus
GS350Lexus's Avatar
too picky it looks awesome
Old 04-18-10, 05:23 AM
3GS404
3GS404's Avatar
just give it sometime to settle on, park ur car under the sun for couple hours i think it will automatic shrinks.. if not just go back to the shop and let them redo it.. i believe every shop do give us a warranty on the labor..GL.
Old 04-18-10, 05:43 AM
passnu2
passnu2's Avatar
your fine
Old 04-18-10, 06:02 AM
bigblack06
bigblack06's Avatar
Some of my sensor is covered but mine is made from autobahn, I'll try to post a pic of it if i can so you can see the difference. "But" yours looks fine.
Old 04-18-10, 06:08 AM
jkeifer3
jkeifer3's Avatar
Looks good! You're a bit too picky.
Old 04-18-10, 06:14 AM
migoylim
migoylim's Avatar
It's just normal!!!!
Old 04-18-10, 07:12 AM
worker
worker's Avatar
the bottom one, dust will collect under there.
Old 04-18-10, 07:52 AM
TWong350
TWong350's Avatar
The slight gap around the sensor is normal. Mine is the same way. The part that is lifting is not normal though, IMO.
Old 04-18-10, 11:07 AM
worker
worker's Avatar
THe last pic, you can use the heat gun and press it in to get it stick to the surface.
Anyway, I used clear bra before and it wasn't great. My hood had two finish color when I removed it. But it was clean and have less scratch from debris than if I didn't have it.
Old 04-18-10, 11:09 AM
Bambigular
Bambigular's Avatar
Looks good, BTW the clear bra is not going to be exact.
Old 04-18-10, 11:36 AM
ashley1977
ashley1977's Avatar
Thanks everybody, I am glad to hear it is normal, the clear bra near the sensor supposes to look like that. I will try to use heat gun to shrink the lifting part to see if it works!!
Hey Worker,
Would you tell me what color your car with clear bra is? Thanks.
Old 04-18-10, 11:48 AM
RC51TOFUMA
RC51TOFUMA's Avatar
reeeeeelax
Old 04-18-10, 11:50 AM
GS350Lexus
GS350Lexus's Avatar
Can you let us know how much the parts and labor cost you.
Old 04-18-10, 12:04 PM
ashley1977
ashley1977's Avatar
I did partial hood, fender, mirror, whole bumper, headlight, fog light for $500
Quick Reply: Just had the clear bra installed but have problem
