High beams
Old 04-18-10, 12:41 PM
kitphat
kitphat's Avatar
Default High beams
Can anyone tell me if I change the high beams to blue will my drl color change as well???
Old 04-18-10, 12:47 PM
XxGoKoUxX
XxGoKoUxX's Avatar
that's a no brainer, but yes lol..... your NRLS or whatever will still be yellow, unless you replaced them with LEDs
Old 04-18-10, 03:14 PM
rominl
exclusive matchup
rominl's Avatar
it might look a bit better but still very yellow
Old 04-19-10, 12:17 PM
passnu2
passnu2's Avatar
My DRL's are blue (no yellow) So yes you can do this. Just need to get the right bulb
Old 04-19-10, 01:05 PM
jtrue28
jtrue28's Avatar
what bulbs are you running passnu2?
Old 04-19-10, 01:17 PM
IXI187IXI
IXI187IXI's Avatar
when you have your lights on correct? during the day though arent they still yellow?
Old 04-19-10, 02:15 PM
rominl
exclusive matchup
rominl's Avatar
i think that should be. drl is high beam running at like 50-60%. unless you get a very high wattage bulb then at 50% it's putting out very bright whit lights already. but then again when you use your high beam then you are risking burning the harnesses
of course, that's on fully stock housing and harness setup
Old 04-19-10, 02:32 PM
passnu2
passnu2's Avatar
Its the same color as my HID's!! No yellow with DRL on. I will have to check later for you both. Its not a higher wattage. Its the correct bulb. Had them for close to a year now with no issues
Old 04-19-10, 04:41 PM
passnu2
passnu2's Avatar
here you go...
Old 04-19-10, 05:00 PM
*Batman*
*Batman*'s Avatar
Interesting. I would be curious to see daytime DRL pics, and night time highbeam pics.
I just ordered Philips Crystalvision Ultra 9005 to replace the stock bulb. My sense is these will still be yellowish at DRL voltage but will be whiter than the stock bulb.
Old 04-19-10, 05:15 PM
passnu2
passnu2's Avatar
here is all I have...trust me they are not yellow or I wouldn't have purchased myself and turned off the DRL's. I changed out all my bulbs up front and they all match good. I wont be able to get more pics for a few weeks.
Old 04-19-10, 05:50 PM
*Batman*
*Batman*'s Avatar
Looks white in drl mode. In high beam mode it looks bluer than 4750K. Is that a camera illusion or is it really blue?
Old 04-19-10, 05:56 PM
passnu2
passnu2's Avatar
its the camera. I would say it blends in with 5k/6k light color.
Old 04-19-10, 06:18 PM
jtrue28
jtrue28's Avatar
looks good. are the high beams actually on in that 2nd pic?
Old 04-19-10, 06:20 PM
passnu2
passnu2's Avatar
nope, our fogs shut off. That is all, minus my one fog, on at the same time. No pics with the high's on.
Quick Reply: High beams
