Dustless Brake Pads - Suggestions?
So it's time to replace my front pads on my GS430, and I need to go something that is virtually dustless. The OEM pads are horrible, my wheels get dirty within a day of driving.
I'm leaning towards Posiquiet pads from StopTech since I know those are practically dustless. But I'm open to suggestions.
I got the dustless TSIB brake pads after 750 miles on my '08....absolutely no dust and no squeaks. couldn't be any happier.
Yep those are mine. https://www.clublexus.com/forums/3ge...ads-front.html
I have Akebono Brake Pad and they are great. Hardly any dust at all and stopping power is almost as good as stock.
I have Akebono Pro-Acts ceramics on the fronts and they produce much less dust then the OEM pads that were previously on which were terrible with dust. They don't squeak and stop well. They are pretty inexpensive and appear to be of high quality. If I can loosen the frozen stuck bolt on the rear calipers I will replace the rears with Akebono Pro-Acts.
When I did my front brake pads those bolts were also in there really tight and took forever to get out, by far the most difficult process in changing the brake pads. On the front passenger side I actually broke the bolt head off while it was in the caliper trying to loosen it/get it off. Luckily it broke to where I was then just able to take the head half of the bolt out and then flip up the caliper to get the other side out because I thought I was screwed and would need a new caliper or try to deal with somehow getting the rest of the bolt out while it was locked.
When I get my oil changed at the dealership I am just going to ask the mechanic if he can loosen the rear caliper bolts with a torque wrench for me so I can take them off myself when I get home.
