Aluminum Pedals
Oh, CAK 500, you did order the wrong set.....sorry.
Install is easy...I came up with a bracket system to secure them.
![](http://i16.photobucket.com/albums/b13/actolex/New%20GS/IMG00056-20100512-0750.jpg)
Cargym has offered to exchange them for the correct set and cover the return postage, so I am a happy camper.
The rubber feels high quality, soft, but durable. The nubs actually protrude from a sheet of rubber through the holes in the pedal. I was worried that they were going to be cemented to the surface of the pedal and eventually come loose. That's not going to happen. I suppose the only issue with the rubber nubs would be wear over time ... but this stuff is tire-quality rubber, so it seems unlikely it would ever wear down from shoe contact.
The Lexus logo is engraved and colored.
![](http://i832.photobucket.com/albums/zz249/cak500/Pedals/IMG_1133.jpg)
![](http://i832.photobucket.com/albums/zz249/cak500/Pedals/IMG_1121.jpg)
Received the correct pair a couple of days ago and installed yesterday. Footrest and ebrake were easy, but brake and gas were tricky. It was difficult to get the drill in position for the top two holes due to the angle and the curvature of the pedal, but doable with patience. The gas pedal is a little tricky because the screws are a little short. I'm very pleased with how they look and feel.
If I ever want to go back to OE, I can just put the old ebrake and brake pedal pads back on, order a new gas pedal ($18) and a footrest pad ($?).
![](http://i832.photobucket.com/albums/zz249/cak500/Pedals/IMG_1272.jpg)
Couple of questions
1) Is the footrest bigger than originally? If so that would be a good thing.
2) Would the rubber OEM floor mats still fit once these are on? Seems like the footrest and gas pedal sit quite low
3) How exactly do they all go on? a) Can you easily remove the existing pedal covers and b) what ensures that the footrest stays secure (I can see that the others go straight through the other side and are fixed with bolts)
Couple of questions
2) Yes, the OE and F-Sport mats are the same size. The edge of the mat just tucks under the edge of those pedals.
3) The OE rubber pads on the e-brake and brake slip right off. On the e-brake, you must drill two small holes for the bolts. On the brake, 4 small holes. On the footrest, 4 screws go through the OE pad and carpet into a foam-type block beneath it. Since this is a non-functional pedal, I'm not too worried about the screws coming out. If they do, I might insert anchors into the foam or just glue the pedal on. The gas pedal is applied over the OE one with 4 bolts.
Very inexpensive and easy mod.
Staggered3
09-08-17 05:07 PM
selkirk
05-25-15 10:38 AM
