Can I have your opinions please on wheels?
Hi guys,
I am about to pull the trigger on these wheels:
MRR GT1
Finish: Black
19 inch
19 8.5 and 19 9.5 offsets: 35 F and 45 R
Two questions:
1. How aggressive will the car stand with these? Will I need spacers to get the flush look I have at the moment with my OEM 18's? I am running 20mm spacers on all four wheels.
NOTE: I am running on Eibach springs.
2. What size tyres do you recommend should go with these wheels? I do not want a stretched look like this IS
MRR GT1
Finish: Black
19 inch
Two questions:
With your stock wheels and 20mm spacers, you effectively have a +25 offset (outboard). That said, 9.5 +45 will not sit as flush to the fender. I have 20x9.5 +45 in the rear of my 3GS and it's not flush. I will be adding a 10-15mm spacer.
The front should be OK.
You may rub depending on the type and size tire you run but the Eibach's are pretty conservative in terms of amount of drop they provide.
from this post it looks like you won't need spacers if you get the correct offset. I assume they offer the same offset in the rims you want?
https://www.clublexus.com/forums/5374442-post198.html
