Brake Fluid Maintance
1) park on a level ground (obviously)
2) shut off car and do NOT engage parking brake
3) completely DISCONNECT the negative terminal on your battery.
4) jack up the car, take off wheels, and start bleeding
5) start from the brake that's furthest away from the reservoir, meaning passenger rear
6) then driver rear, passenger front, driver front
7) check from time to time to make sure reservoir is full.
you should not have to take out the brake line. you just open up the valves at each caliper independently and bleed through them
One comment...absorbing of moisture by brake fluid not only can cause rust of the internals of the brake components, probably more importantly the moisture decreases the effectiveness and efficiency of the braking system. In cases where you may really need the brakes to be working right...they may fade and not be there for you!
Question---Do these systems require a pressure bleed and/or any other special bleeding of the ABS system? Anyone have the factory service info for brake bleeds on 3GS's?
can't remember how much exactly was needed, but i think i only used 1 bottle (quat / lt)?
