Check system error
Hi, I went and filled up my tires today, and I pressed something in the setting. Now there's an error that says "Check system" and the caution signal keeps flashing. Does anyone know how to clear this?
to fix it all you have to do is take it down to the Lexus dealership service drive and they will have you in and out in less than 15 minutes. You can also just call your service rep and ask him to walk you through the steps to clear it over the phone. My guy once walked me through how to reset the service light right over the phone.
Make sure the button for the TPMS is set in the main position. It is way underneath the glove box.
Read this: https://www.clublexus.com/forums/gs-...xperience.html
I think I accidently put lower grade gasoline in the tank and it caused errors. Is this possible? Has it happened to anyone? It actually happened right after I filled up gas.
