TPMS in asantis
TPMS in asantis
My local wheel guy says that he would prefer to drill an extra hole in my asantis to install the TPMS sensor as opposed to using those adapter. He claims this is the best thing to do although it requires more work. any one have feedback on this? i guess i can't think of any negatives besides it looking bad and resale value
They want to charge 140$ which doesnt seem too bad to take off my stock tires, take off the tires on my asantis. drill new holes in the asantis. put on the sensors. and reinstall all tires.
exclusive matchup
it's not as much about the size of the hole, but the location and angle. a lot of aftermarket wheels the valve stem hole is at a wrong angle so can't just install the tpms like that
me personally, i prefer drilling another hole at the back of the wheel (if the design allows). i am never a fan of using those adapters. i have heard too many cases of tpms falling off, etc...
hunt on ebay.
you can get these
http://www.360bc.com/
i would put some red loctite on the setscrew, crank it in, doubt it will fall out.
hunt on ebay for variations
you can get these
is it really receesary to even put the tpms on? it jus sucks when u go back t your stock and have to take them off and on whenever u need to switch to your stocks and back. Unless of course you jus buy an extra set but heard its an arm and a leg to buy?
When it comes to sensors you don't have to it's really a personal choice. However the best option is to have them drilled. You should tell him to cut you a deal though because he should have asked if you wanted the tpms sensors pre-cut because it is standard procedure and Asanti doesn't charge anything for it.
$150 for sensors isnt bad but if u have to tKE IT TO THE DEALER TO RECALLOBRATE THEM it can get expensive.....which is y im opting to use my sensors in my stocks
im using these adapters on my asanti's. Had them for 3 years no problems at all except one of my sensors just went bad last week. Have a felling it was the tire shop when I switched to 245/30's on the front, they had trouble putting the tire on past the sensor.
