GS + Vossen Concave Owners: i have a question, need help!
Old 06-05-10, 04:21 PM
Lex Luga
Lex Luga's Avatar
Default GS + Vossen Concave Owners: i have a question, need help!
What Lug Nuts do you use and which socket? I was told by someone at Vossen that they dont supply lug nuts, but to get 19mm lug nuts and to use 19mm socket + breaker bar.
So i tried the 19mm lug nuts and they fit BUT, the 19mm socket doesn't even fit in the hole (where the lug nut would be placed into) so i cant even screw it and tighten it in.
Very frustrating bc i had these wheels in my house for 2 weeks now and want them on my car already!!
Old 06-05-10, 06:05 PM
ek9vboi
ek9vboi's Avatar
That is with any set of aftermarket wheel. You should go to Sears and look for the craftsman 19mm "thin wall" sockets. Make sure you get the long socket.
Old 06-05-10, 06:09 PM
Lex Luga
Lex Luga's Avatar
I got the 19mm deep impact socket aka the long one, but i dont think its thin wall socket.
Ill check it out tomorrow..hopefully that does the trick
Old 06-05-10, 06:30 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
personally i have always used the mcguards spinal. much easier to use imho and never hurt the wheels
Old 06-05-10, 09:08 PM
Lex Luga
Lex Luga's Avatar
what is mcguards spinal
Old 06-05-10, 09:25 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
here are more information
http://www.mcgard.com/Home/Automotiv...neDriveLugNuts
with the mcgard, the key is so narrow it never touched the wheel face, love them
Old 06-07-10, 09:24 PM
Lex Luga
Lex Luga's Avatar
the thin wall socket worked perfectly...now just have to get a wheel alignment
Old 06-07-10, 09:25 PM
ek9vboi
ek9vboi's Avatar
Cool, you shouldn't have a problem with getting them to spec sitting on the S techs.
Old 06-07-10, 11:02 PM
CBRA928
CBRA928's Avatar
kind of off topic... i have the NF210... should i be able to get car aligned to specs? the place was saying camber in rear is off and cant be adjusted
Old 06-08-10, 12:28 PM
DarkknessD
DarkknessD's Avatar
let's see some pics
I'm looking to get a set of the Vossen VVS CV1's as well.
Old 06-09-10, 09:04 AM
envious
envious's Avatar
I just got the VVS CV1's, the machine and matte black version. They look wicked, ill be posting a bunch of pics soon, once my springs settle and I get the car waxed...
CBRA928:
I got NF210's aswell, and will need alignment soon, any updates on your situation?
Old 06-09-10, 10:18 AM
IXI187IXI
IXI187IXI's Avatar
agreed! this is the only set of lugs i ever buy.
Old 06-09-10, 11:41 AM
CBRA928
CBRA928's Avatar
CBRA928:
no not yet, i wanted to hear from some memeber before i go back to the shop
Old 06-09-10, 02:41 PM
I8ABMR
I8ABMR's Avatar
alignment will still be off. Not as much as a DF210 but it will run through tires faster than the stock height for obvious reasons. The only spring I have seen that you can get the outside of the factory specs on alignment would be the H techs but they barely even lower the car.
Are you running a staggered set up or even width all the way around??? The tire wear will be slightly better if you do the same width but the staggered set will look better and more aggressive
Old 06-09-10, 02:59 PM
CBRA928
CBRA928's Avatar
im running staggered... 245's in front and 285's in rear
Quick Reply: GS + Vossen Concave Owners: i have a question, need help!
