Squealling brakes??
Old 06-24-10, 10:01 AM
designo
designo's Avatar
Originally Posted by Rider
Our dealership has just one philosophy.. which is "replace".. easiest and most profitable way.
They should rename their business from "service and repair" to "service and replace"
Old 06-25-10, 11:56 PM
snaker314
snaker314's Avatar
I also have an 07 GS350. After a couple of months and many wheel cleanings went back for the dustless brakes. This year the brakes were squealing bad when I was driving slow. Neighbors knew when I was leaving in the AM. Took it back for the windshield rattle and mentioned the brakes. They replaced the pads and shims under a TSB. At least that's what they told me and charged me nothing. So far, very quiet.
Between the rattles and squeaks it's been an acoustical adventure. Right now very quiet. Waiting for the cold weather for the stress test.
Old 06-26-10, 10:05 AM
Rider
Rider's Avatar
HMM... after my pad change I feel a slight decrease in stopping power + rims are not as dusty... so I am guessing I got the tsib pads.. which tbh are not what I was looking for. How can I make sure?
Old 06-26-10, 11:04 AM
chuckGS350
chuckGS350's Avatar
They should replace the shims, pads, and front rotors under a new TSB last year. It should be free of charges.
There will be an increase in stopping distance with new pads & rotors.
I am not heavy on gas pedal so it's not a problem.
Old 06-26-10, 11:09 AM
Bushwack
Bushwack's Avatar
Do you have a link where I can find this TSB?
Old 06-26-10, 06:39 PM
chuckGS350
chuckGS350's Avatar
I subscribe to alldatadiy.com.
If your car is still under basic warranty, the repair should be free. Or if you brought up this issue before the basic warranty expired, it should also be free of charges.
This TSB is different from excessive dust pad TSB.
My service dealer did the dust pad TSB, but it only lasted a few weeks and the noise
even got worse.
I had to wait for several months while Lexus engineers worked on the new rotors.
Had the repair done last June 09. So far no noise.
Here's the TSB#.
L-SB-0040-09
April 17, 2009
Front Brake Squeak (AWD)
Service
Category Brake
Section
Brake (front)
Old 06-27-10, 12:57 AM
snaker314
snaker314's Avatar
Interesting. Hadn't noticed anything. But now that I'm aware I'm sure I will.
Old 07-25-10, 03:16 PM
Alex247
Alex247's Avatar
Yes replace the pads with oem pads if it doesn't help replace the rotor on the side that squeaks. I had the same issue but was solved with oem pad. Lucky me.
Old 07-29-10, 08:43 AM
JBasco20
JBasco20's Avatar
I had the tsb done on my 430 a few months ago... New rotors,pads and shims.... It's been silent since the repair...
MnGs3xx
03-13-16 05:29 PM
2010ISF
IS F (2008-2014)
17
07-21-15 03:54 PM
lexrally
RX - 1st Gen (1999-2003)
13
07-15-15 01:18 PM
tbilisi79
09-21-14 03:42 AM
1HottLex
Suspension and Brakes
14
01-13-07 05:22 PM
Quick Reply: Squealling brakes??
