Cross drilled and slotted Rotors
Old 06-23-10, 09:13 AM
bimori
bimori's Avatar
Default Cross drilled and slotted Rotors
So for those with cross drilled and slotted rotors, do they squeal when cold??
Old 06-23-10, 10:32 AM
passnu2
passnu2's Avatar
you better to get just slotted.
Old 06-23-10, 11:03 AM
bimori
bimori's Avatar
Thank you passnu2. i just ordered slotted. Do they make any noises at all?
Old 06-23-10, 01:59 PM
ReyRey305
ReyRey305's Avatar
Yes they make noise. The air blows through the little holes and makes a whistling noise instead of squeeking...
LOL, just joking... No they dont make noise, its your old shims that are vibrating making the squeeling noise. Make sure you change you pads and shims.
As far as cross drilled rotors DO NOT get them ! You are actually better off getting stock rotos or OEM ones. But if you want to choose go with Slotted. The air flows through the grooves to cool down pads and brush off brake dust slightly...
If you have a race car then go with drilled and slotted...
Old 06-23-10, 02:20 PM
designo
designo's Avatar
I don't agree. For heavy braking, slotted discs are better than drilled. Drilled rotors are known to crack.
However, if you want for normal road use, it doesn't matter! Just go with what looks good. I have drilled and slotted rotors, and they are perfect.
Old 06-23-10, 02:30 PM
ReyRey305
ReyRey305's Avatar
You dont agree with what ? Do you really think your rotors actually made a huge differrance than OEM rotors ? And yes the drilled ones do crack over time and expecially if you get cheap drilled rotors... In reality, the average person is better off getting OEM rotors...
Old 06-23-10, 09:32 PM
designo
designo's Avatar
Hi ReyRey
I don't agree with what you said about having a race car and going for slotted and drilled rotors.
My new rotors made a huge difference from OEM rotors. They don't squeal, and that's a huge thing for me you know!
I'm not an average person, if I was.. I wouldn't have riced up my Lexus.
Old 06-23-10, 09:50 PM
erik535353
erik535353's Avatar
Try brakeworld.com. I got my drilled and slotted rotors from them and they are top notch. As said above they stop far better and I don't have the squealing like I had before with the OEM rotors.
Santos.L.H
Suspension and Brakes
29
06-15-24 02:01 AM
ReyRey305
08-02-11 11:58 PM
Anthai
IS - 1st Gen (2001-2005)
12-04-08 08:50 AM
CAMAracer
05-08-08 06:59 PM
Mr GS400
03-27-02 07:54 AM
Quick Reply: Cross drilled and slotted Rotors
